Anyone know where I can get an extra firm spring for the above?
Talk to Hotlines? Always been helpful when I've e-mailed.
If it's for the 120mm fork the part number's 83-3177.
Hotlines might even have one in stock.
It's for the 100mm version, I'll give hotlines a call tomorrow.
For 100mm you need 83-3172
Cheers thanks for part numbers. Hope it's easy to change?
i've mailed you the service manual and parts diagram.
it's the 2009 one but everything's the same.
Right spoke to hotlines they have informed me that the spring was used on the 2007 minute comp, if that's so would this....
http://www.chainreactioncycles.com/Models.aspx?PartnerID=79&ModelID=38245
....be ok to use also tf tuned have an 2006 extra firm in stock, the tf one would be a better choice โ
I'm also looking for an x-firm spring/ride kit for 2010 Minute 29er 120mm...I phoned manitou USA and their tech support guy said the parts diagram for the 29er minute forks in the 2009 service manual is wrong. He said the parts listed under the 29er fork are for the 26er. He gave me part number 141-26744-K003. I had already ordered part number 83-3177 as per the manual and the above post but he said that part is for the 26" model. I phoned hotlines and TF tuned with the part number and they said it didn't show up on their system at all and it doesn't come up in any web searches. Manitou USA have them in stock but only sell to dealers. I'm confused? Can anyone shed any light on this?
As a slight hijack, anyone altered the travel of the 29er minutes? Which parts need changing? Manitou seem a bit deficient in thewebsite tech resources/downloads....
