Anyone know if the travel on these can be upped to 120mm from 100mm?
Not sure about the teams but i think i read a thread a while ago saying that you couln't up the newer ones.
I bought some 2010 Reba RL for my GFs hardtail and was toild they couldn't be upped to 120. The 2009 and go up to 115mm i think
If they're the white ones, with white crown, 'power bulges' and pop lock remote, then I'm fairly sure the answer is yes, as I've done it to mine. Requires the removal of a 20mm internal spacer.
Yep, those are the ones. Did you get yours from Merlin?
Yep, from merlin sometime last summer. Good forks but the lockout doesn't seem to 'lockout' as firmly as the older motion control type. Searching on the various forums suggests that this is normal for the blackbox ones.
