200x57 shock on Sup...
[Closed] 200x57 shock on Superlight? Or should I hold out for a 200x50?
Following on from my earlier post (broken shock), if I put a 200x57 fox rp2 on instead of a 200x50 will this cause significant issues? The geometry won't change, but presumably there becomes a risk of the swing arm hitting the seat tube? Anyone got any experience of doing this? Btw, it an old style superlight frame, circa 2001.
Ta
(The reason I ask is all the shocks I can find are 200x57 and I need it quickish)
Posted : 11/07/2013 11:33 pm
Bump
Posted : 12/07/2013 7:42 am
Buy it, try it and see.
If the worst happens and it does hit the frame (unlikely as the tyre would normally be in the way) then just fashion a 7mm spacer to reduce the stroke length
Posted : 12/07/2013 7:49 am
