200mm rear rotor o...
[Closed] 200mm rear rotor on a 456?
 ton
put a 200mm rotor on the back of my 456. it is a gnat's hair away from the stay. is this ok?
Posted : 30/01/2012 11:00 am
 br
it'll be fine, or it'll bend and take lumps out - but why do you need a 200 on the rear, a 140 will lock up the tyre?
Posted : 30/01/2012 11:06 am
 ton
cos i am a colossus of a man.......... ๐Ÿ˜‰
Posted : 30/01/2012 11:22 am
Absolutely fine, had a 203 on mine with no issues.
Posted : 30/01/2012 11:27 am
 D0NK
with the hand strength of a little girl ๐Ÿ˜‰
Fe C or Ti version btw?
Posted : 30/01/2012 11:32 am
 ton
bastid........ ๐Ÿ˜€
steel
Posted : 30/01/2012 11:42 am
 td66
I've used a 203 rotor on a steel 456 for a while, no problems.
Posted : 30/01/2012 11:47 am
 loum
If it doesn't fit, you can tie a thick rope to it and use it as a traditional anchor for when the storms blow in ๐Ÿ™‚
Posted : 30/01/2012 12:10 pm
