2007 Giant Reign2 H...
[Closed] 2007 Giant Reign2 Headset Bearings
As mentioned above I am looking for some new bearings and all ii can tell is that the headset is Aheadset make and the bearings are the ball bearing type that fir in a "cage" if that helps. Anyone know where best to get them from?
Posted : 08/06/2010 2:28 pm
a local bike shop will be able to sort you out with some no problem - just take an old bearing in with you so you get the right size
also bear in mind that often upper and lower bearing are a different size.
Posted : 08/06/2010 2:43 pm
They are a different size i know that as i have had them out on a regular basis to re-grease. Will call the LBS and ask them.
Posted : 08/06/2010 2:44 pm
Just called DNA cycles in Maidenhead and they want £30 for the top and bottom bearing... is that about right...seems allot to me but maybe I’m just out of touch.
Posted : 08/06/2010 3:52 pm
Different subject I know but if you're (Warrenpfo) thinking of selling mint TALAS 36's pls get in touch email in profile, cheers, Simon
Posted : 08/06/2010 4:03 pm
Way to much £30.
Off the top of my head think they are 1 1/8" 36 x 45 degree bearings - like these:
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=11266 ]http://www.chainreactioncycles.com/Models.aspx?ModelID=11266[/url]
I can check tonight as a have an 07 Reign frame.
Posted : 08/06/2010 4:10 pm
Zangolin they are like this:
http://www.chainreactioncycles.com/Models.aspx?ModelID=2222
but not those ones as i bought them without measuring and the dont fit but are the same style.
Posted : 08/06/2010 4:17 pm
Sorry did not read your post properly!! 😳
Would it not be better to just get a new sealed A-Headset
Like this for a tenner:
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=44797 ]http://www.chainreactioncycles.com/Models.aspx?ModelID=44797[/url]
Posted : 08/06/2010 4:34 pm
Could be but is that top or bottom or both as it only looks like half?
Posted : 08/06/2010 4:38 pm
No that's the whole thing - not much to these integrated headsets.
Basically 2 angled bearings, crown race, wedge washer/spacers, top race cover.
Posted : 08/06/2010 4:41 pm
Ill give it a go then and order one
Posted : 08/06/2010 4:45 pm
 benz
So, per Zangolin, would the same fit my 2006/7 Trance I wonder?
Thanks!
Posted : 09/06/2010 2:16 pm
