Ok quicky - looking at some Deemax
2006 Mavic Deemax - the rear hub - is apparently 135mm 10mm bolt.
Now were they 10mm bolt up like the hope hubs - i.e. 2 10mm bolts one from each side of the hub or were they a proper bolt through.
Basically can you run them in a standard qr `135mm rear end or do you need a proper bolt through compatible rear end?
J
Posted : 14/08/2009 4:03 pm
yep bolt on not bolt thrpugh so work fine in a qr rear
Posted : 14/08/2009 4:54 pm
Cheers for the clarification - Much appreciated!
Posted : 14/08/2009 5:07 pm
