When you run a 1x9 set up do you just bin off the granny ring and the outer chain ring and front mech? Or do you tend to go for a different number of teeth on the single chain ring?
Went smaller on the middle ring - 33t renthal as i like nice things & they are only round the corner.
Just binned the big & small rings from my triple, will get so dedicated single rings cranks at somepoint
32-34 teeth is generally what people run, you might need some single ring chainring bolts.
i run a 36 front and 11/34 rear good for everything with a lg1 device
Shorter chain ring bolts, chain guide.
I kept the same number of teeth [34] but dedicated single rings are nice, they aren't made for shifting so have higher teeth and are less likely to throw the chain. Not a big issue with a chain device or if you keep the front mech.
Kept the 32 middle ring and ditched the big and granny on my heavy bike.
Switched to a 36T middle on my light bike.
11-34 on both.
Chain device on both.
It's strangly liberating!
I run a 40t plus chain device. Got removable spider cranks and shallow bolts.
Or add a bash/guide ring.
I'm 1x9 with straightline silent guard. 32 up front and 36-11 on the rear no issues. would probably get away with a 34 up front but for steep sustained Scottish climbs I like having the option.
Bike is silent apart from tyre noise.
Great.
I wont be going back to 2 or 3 rings up front.
