1x10 setup options:...
[Closed] 1x10 setup options: top-only chain device plus bashguard?
I'm looking into options for a 1x10 AM setup with a 32t chainring. The rear mech will be a clutch type (SLX Shadow Plus most likely), so no need for a full chain device, just the top "cage" type, but I'd also like a bashguard. So looks like the possible options are:
1: Full chain device (eg. e13 SRS+, e13 LG1+, MRP G2) with the bottom device removed (cut/filed off if necessary). The clutch rear mech negates the need for the lower part and removing it will keep things quieter and with less resistance.
2: Top-only seatpost-mount device (eg. e13 XCX, MRP 1x) plus ISCG-mount bashguard ([url= http://www.mountainracingproducts.com/mrp/xcg/ ]MRP XCG[/url] is the only one I've seen).
3: Top-only device (XCX or 1x) plus full bash ring - not sure if these are compatible.
Any advice?
Posted : 11/11/2012 1:29 pm
I found bike was quieter and did not notice any resistance with a bottom Roller. No Clutch mech on my setup though.
Posted : 11/11/2012 1:32 pm
Running a 1x on my 1x10 but I don't have a bash it's also designed I believe to be used without a bash, I can see it wouldn't work with a bash though as it sits on top of the chainring pretty mush and is quite wide so would rub.
Posted : 11/11/2012 5:44 pm
Why not just use an ngear jump stop & bash? Lighter & quieter, no fuss to set up either
Posted : 11/11/2012 5:48 pm
Hope have what you're looking for OP. nice bashring and top guide, can buy separately and they look mint...
Posted : 11/11/2012 5:56 pm
Superstar do a BB mount bash compatible guard for approx £16, I've ordered the non bash version. AFAIK their seattube mount guide isn't worth the packaging it arrives in, but I've heard good things about the BB mount guide. Couldn't justify £35 for an MRP or Ethirteen guide.
Posted : 11/11/2012 6:01 pm
I'm keen to avoid anything with a BB mount because I may switch back to 2x10 occassionally and it would be a lot of hassle to remove a BB mounted device compared to something ISCG or seatpost mounted.
A Jump-Stop plus bash ring or an inner + outer bash ring setup did cross my mind, but still a chance of the chain jumping out the top, isn't there? This is my AM bike, often ridden on very rough terrain in the Alps.
Thanks Woody for the Hope info. Looks like a good solution but pricey (£45 for the ISCG or seattube version, plus bashguard or Hope's integrated chainring/bash). I'll surely go with this option or a modified LG1+ or G2 Mini if I find a deal on one.
Thanks for the help everyone.
Posted : 11/11/2012 6:22 pm
I have an N-Gear Jump Stop (and bash) and I've never lost the chain whilst riding. However, now that we're in the mud and loose foliage of autumn it's proving a bit annoying - today we were sessioning some new DH tracks in the woods and it kept getting clogged up and then twisting out of position whilst we were pushing back up, with the chain occasionally coming off and getting stuck below it. Top and bottom guides are overkill for me, I like having a bash ring, and I don't have ISCG tabs. I'll have a look at that Hope one...
Posted : 11/11/2012 6:53 pm
I run a Straitline Silent guide on both my bikes (both 32t, one is 1x10 the other 1x9). Excellent - pretty quiet, no drag, robust, tidy.
Posted : 11/11/2012 7:01 pm
Same here! 2 bikes (1x9 and 1x10) 32t, both Silent Guides, not problems. Smashed it off plenty rocks and it doesn't care. Unlike the MRP/Gamut devices I've gone through.
Posted : 11/11/2012 7:28 pm
 benz
Bash(BBG) and Radium inner?
Posted : 11/11/2012 8:06 pm
The Hope integrated ring is nice. Very neat.
Posted : 11/11/2012 8:21 pm
using a straitline bash as i had it already, and an xt clutch mech and not dropped the chain even once since. much lighter and quiet due to mech. wouldn't bother with any front guide unless you find you definitely need it. what bike?
Posted : 11/11/2012 8:53 pm
I used a e13 freechucker and sunline bash
Posted : 11/11/2012 9:16 pm
[b]foureyes[/b]: Nukeproof Mega, riding AM in the Alps so I'd feel more confident with something holding the chain at the top. You think I'd be OK without?
Posted : 11/11/2012 9:33 pm
I put one of these on the outside
http://www.chainreactioncycles.com/Models.aspx?ModelID=40144
And one of these on the inside
http://www.chainreactioncycles.com/Models.aspx?ModelID=17283
Never lost the chain and looks ultra neat
Posted : 11/11/2012 9:59 pm
hah im not in the Alps, suspect if it was me there i wouldnt want to take a chance i see your point.
Posted : 11/11/2012 10:21 pm
