1x10 - do i need a ...
[Closed] 1x10 - do i need a chain device?
if i'm fitting an SLX clutchy type rear mech?
Posted : 30/01/2013 12:56 pm
Yes
Posted : 30/01/2013 12:57 pm
maybe
probably ok with a dedicated single ring tight chain and mincing.
For everything else get a nice light e-13
Posted : 30/01/2013 1:05 pm
I tried 1x8 on an XC bike many years ago (with short mech and 12-28 cassette) and it fell off at least once every ride even on smooth XC stuff.
Not sure how much help a clutch mech is yet but I'd probably pair it with one of those minimalist top guides and a light bashring.
I've got a full chain device (upper/lower/bash) on my Pitch as the BB is really low and I wanted to protect the chainring, but it's overkill for chain retention.
Posted : 30/01/2013 1:14 pm
righto
who sells those lightweight csixx carbon top guides?
Posted : 30/01/2013 1:19 pm
I was going to ask the same question (1x9 on an old FS). Good god those e13 things are 60 quid!!! ๐Ÿ˜ฎ
Posted : 30/01/2013 1:21 pm
Perhaps not if you buy an XX1 chainset...
If the bike needs all that gubbins half the advantage of going 1xX is thrown away surely?
Posted : 30/01/2013 1:22 pm
Cheaper available, though better isn't
Just a top guide really, depends where you ride. Try Superstar.
Posted : 30/01/2013 1:37 pm
are the superstar ones *actually* any good? been bitten by SS stuff in the past...
Posted : 30/01/2013 1:45 pm
Yep, I had the SS one ST mounted guide on for Llandegla recently... it doesn't move even a fraction.. however the little grub screw needs to be tighter than you think ๐Ÿ™‚
But now it's fitted, it's a fit and forget thing.
I am running a Renthal front ring, but have not fitted the SGS rear mech yet.
I've not dropped the chain once in 300 miles including some jumps/rocks etc.
Posted : 30/01/2013 2:08 pm
was that the chain keeper of the full top guide?
Posted : 30/01/2013 2:24 pm
cool. cheers weeksy!
Posted : 30/01/2013 2:30 pm
BB mount Superstar one is alright- little bit flimsy and the chain control's not the best Fiddlier to set up too. If you can stretch to a better one like the E13 1X, I'd definitely recommend it.
Posted : 30/01/2013 2:38 pm
well i've ordered the seatpost mount one, budget doesn't allow for new cranks/BB so old SQ taper BB/cranks for the time being.
Posted : 30/01/2013 3:08 pm
They're a little bit of a faff to set up, but TBH after it's done, they don't exist... .they just do the job well.
Posted : 30/01/2013 3:14 pm
I've bent two SuperstarOnes (Tube mounted as my cranks have a different chainline to the standard Shimano and my frame is plastic pressfit job) since modding it with plastic I haven't had any problems.
Posted : 30/01/2013 3:21 pm
I take then that ou just need to get it as close to the chainring as possible without fouling the bolts or rubbing?
Anyone got any pics of theirs?
Posted : 01/02/2013 12:32 am
