1x10 chainset - dou...
[Closed] 1x10 chainset - double/triple and lose the other rings?
 tor5
This has probably been done to death but searching hasn't turned much up. I'm planning on going 1x10 on a new build, but unsure what chainset I need.
Will I die if I buy a shimano chainset (SLX/Deore depending on deals), sell/keep for spare the rings and put a specific 1x ring on? Anything else I ought to know?
Cheers!
Posted : 21/05/2013 7:53 am
I'm running 1x10 on standard XT crank, with a Raceface unramped ring. Singlespeed type ring is best to prevent chain drops (still need a chain device though). There are now XX1 style chainrings thta help keep your chain on without the need for a chain device, i'm waiting for one to arrive in the post.
Have you got a clutched rear mech?
Posted : 21/05/2013 7:57 am
 tor5
There is one in the post 🙂
Where did you get your XX1 style ring from?
Posted : 21/05/2013 8:10 am
I've ran a single specific ring and also a middle from the SLX crankset, no issues with either.
Posted : 21/05/2013 8:11 am
www.wolftoothcomponents.com
Posted : 21/05/2013 8:15 am
 Keva
I'm running 1x9 on SLX cranks and shifter with a standard 36t chain ring on the middle. On the outside there's a bashguard to stop the chain going over the top and an Ngear jump stop to prevent it falling inside.
http://n-gear.com/whatis.html
Posted : 21/05/2013 9:19 am
I still run standard rings and it's always been fine. I'd just ditch the inner and outer then run the 32t it came with until it dies.
Posted : 21/05/2013 9:23 am
how does it not derail tho luke?
Posted : 21/05/2013 9:24 am
Because I have a chain device. There are still teeth on the ring, still holes in the chain. And I saved about £20 by buying a Deore ring over an E13 fancy pants one. I've run them since I went 1x10 3 years ago- if I see a good deal on a proper ring I'll upgrade, but till then I'll stick with what's cheaper.
Posted : 21/05/2013 9:38 am
 Leku
I have 1 x 10 on the hard-tail. SLX clutch mech and Race Face bashguard and have never dropped the chain.
Get a triple chainset so single ring sits in middle with bash in outer position. Double chainsets are much harder to convert.
I have one of these;
http://on-one.co.uk/i/q/CROOSS/on_one_stainless_chainring
Posted : 21/05/2013 9:53 am
I've recently converted from 2x10 to 1x10 by simply ditching front mech and replacing outer chainrign with bashguard. I've a clutch mech and so far absoltely no problems whatsoever. I don't plan to replace the front crankset at all, unless I were to go 1x11.
Posted : 21/05/2013 10:11 am
 tor5
Excellent stuff, thanks all. Just ordered a triple and will remove inner and outer rings - may/may not fit a bash or single ring specific once I've ridden it a bit.
Posted : 21/05/2013 12:02 pm
My 1x10 setup has Deore cranks, and an e*13 Guide Ring. Never had any issues despite them by 3* cranks. When I have the money I shall be looking for some XTs though as Deore weighs a tonne.
Oh, and I'm only running a top guide (one of the hope ones with a hope bash) and an XT clutch mech.
Posted : 21/05/2013 12:13 pm
