160mm fork on a 201...
[Closed] 160mm fork on a 2010 Trek Remedy?
I've got a 2010 Trek Remedy with 150mm Revelations at the moment. Has anyone put a set of 160mm forks on these frames? I'd like a set of the new X Fusion Slants which are about 15mm longer a2c. How badly will this raise the bb and throw off the handling? Dont mind a slightly slacker HA
Posted : 07/02/2013 10:39 pm
Trek don't warranty the Remedy for a 160 fork incidentally - I doubt it will hurt it, they came with 160s at first, but that's their official line.
Having said that, I have several friends hammering merry hell out of Remedys with 160 36s up front, with no issues, and they all preferred the advantages of the 160 setup to any disadvantages.
Posted : 07/02/2013 10:42 pm
Do it.
Posted : 07/02/2013 10:44 pm
I had a 2009 remedy that came with 160mm Lyrics,it worked very well.
Posted : 07/02/2013 10:58 pm
I had 36's on my 09 Remedy was great
Posted : 07/02/2013 11:39 pm
 DeeW
I ran 160mm 36s on my 2010 remedy. It was a warranty replacement for a 2009 frame and no geometry changes from the 2009 bikes which came with 36s as standard . Do it, but will void your warranty if you tell Trek.
Posted : 07/02/2013 11:58 pm
I am currently running a Remedy R8 2008 that came from Trek fitted with 160mm Lyriks...Not sure what the difference is to the newer frames if Trek don't warranty them for 160mm now....May be worth contacting distributor for advice.
Posted : 08/02/2013 12:04 am
uturn lyriks on my 2012 Remedy. Handles a treat. You'll be fine.
Posted : 08/02/2013 8:25 am
Put 36s on my Roscoe, which with its abp pivot and drcv shock Iowans very similar to the current Remedy... It' worked a treat
Posted : 08/02/2013 8:48 am
10mm is never going to cause a problem!
Posted : 08/02/2013 9:14 am
Like for like, you're probably right. But a 36 is a pretty tall fork & has a much bigger A2C height than a RS Rev. There is probably a good inch's worth of difference between the two.
Posted : 08/02/2013 9:37 am
There's a 15mm a-c difference between the revs and float 36's, when sat on the bike with the forks sagged do you think it would be noticeable?
Posted : 08/02/2013 9:43 am
