15mm maxle.-much be...
[Closed] 15mm maxle.-much benefit over a std front qr fitting?
Currently running a std qr on a set of 100mm travel recon gold 29er forks, would I notice much benefit upgrading to a 15mm bolt through setup?
Posted : 02/02/2016 1:23 pm
15mm is much better than QR. Significant improvement but strength and stiffness also come from the fork construction
Posted : 02/02/2016 1:24 pm
It'll be stiffer. Question is, will you care. I went back and forth between a set of lyriks and a set of QR 130mm revelations for a long time, sure the revs were noticably far more flexy but it only took a moment to get used to it and it was never a problem, for me. But for some people it's important.
Posted : 02/02/2016 1:28 pm
QR forks on my hardtail, 15mm forks on my 'other' bike. I don't worry about it enough to see if i can tell the difference.
i certainly wouldn't spend any money to replace qr forks that still work just fine.
Posted : 02/02/2016 1:56 pm
I've QR, 15mm and 20mm on my bikes and get way more lady winks with the 15mm, fact.
Posted : 02/02/2016 1:58 pm
You wont notice any difference. How much give can a tightly clamped hub have?
Posted : 02/02/2016 2:03 pm
scottalej - Member
Having watched wheels flex around a 9mm axle on QR you can see and tell
Posted : 02/02/2016 2:05 pm
As above 15mm will be stiffer but in my experience 15mm will be heavier & with qr forks you can use either qr wheels or adapted 15mm wheels whereas not many qr wheels can't be adapted to fit 15mm forks - either of which you might not give two figs about
Posted : 02/02/2016 2:06 pm
Sold on the lady winks lol
Posted : 02/02/2016 2:49 pm
If you can get adaptors for your hub (Hope?) then you could try a 9mm QR thru axle without having to upgrade your forks.
http://www.superstarcomponents.com/en/9mm-front-qr-through-axle.htm
Posted : 02/02/2016 4:39 pm
sandwicheater - Member
Thats the see through lycra...
Posted : 02/02/2016 4:46 pm
on a 100mm fork, not much difference in real life
Posted : 02/02/2016 4:49 pm
