140mm Fox Floats on...
[Closed] 140mm Fox Floats on a cotic soda?
As the title says.
What do you reckon?
Ok or not?
8)
Posted : 17/08/2009 7:18 pm
What's the axle to crown?
I run 130mm Marzocchis on my Simple which are about 520mm and I love it.
Does the Soda have the same geometry?
Posted : 17/08/2009 7:25 pm
Too long. I run 140 talas on mine at 120mm. Handles great
I run the 140 when I am doing big downhills in Spain. I think a 140 fixed length fork is too long for everyday use.
MM
Cheers guys
I was think of running them with a touch more sag to lower the front a bit.Does that sound about right?
Posted : 17/08/2009 7:28 pm
You could reduce the travel internally
Posted : 17/08/2009 7:31 pm
ir_bandito
yes the geometry is the same. and it is 520mm axle to crown.
Is the extra 10mm going to cause to much extra stress on the frame?
Posted : 17/08/2009 7:35 pm
shouldn't have thought so - send an email to Cotic to check. Ultimately, it depends if you're an 8st xc whippet riding round Thetford (should be fine) or a 20st biffer riding in the Alps (you'll probably break it).
Posted : 17/08/2009 7:47 pm
if its the same deal as the Soul then you'll void your warranty.
theres a post on here somewhere saying Cotic allow 130mm or some measurement I forget [b]whichever[/b] is the smaller...
personally if its the same geometry I'd not like it much as a soul is wandery enough at (Van) 125mm.
Posted : 17/08/2009 10:49 pm
cheers metalheart i am going to contact cotic today
Posted : 18/08/2009 6:42 am
