New frame runs 135x10, have bought new hope pro2 evo's on flows, what do I need to convert rear hub to run135x10?
Posted : 05/09/2012 6:24 pm
135x10 is standard rear hub dimensions. It'll slot straight in
Posted : 05/09/2012 6:27 pm
The wheels come with QR for running your standard QR 135mm, or as I have done you can buy 135 x 10 adapters for bolt through QR I'm using a DT Swiss 135 x 10 RWS gives a bit more stiffnes to the rear.
Posted : 05/09/2012 6:32 pm
Or if you actually meant 135x12, there are other end caps you can buy which pop on.
You might have to remove the cassette, think I did for my 142x12s
Posted : 05/09/2012 6:33 pm
Cheers it is for a new transition bandit frame.
Posted : 05/09/2012 7:20 pm
