135mm skewer option...
[Closed] 135mm skewer options (qr / 10mm / 12mm)????
[#1590459]
I'm building a dh/fr bike that has 135 dropout spacing. The rear wheel will be running a Hope Pro2 (135mm).
I have always used 135mm qr for all my bikes in the past and I'm not really up to speed on the rear axle options available these days. I hear of 9/10 and 12mm options but I'm not sure whats what.
What options can/should I run which work with the 135mm Hope Pro 2 hub. Hub is in qr mode so pointers on how to change if necessary would be helpful.
Many thanks
Posted : 09/05/2010 8:27 pm
Maxle here on my Nicolai, with Pro2. Faultless.
Posted : 09/05/2010 8:31 pm
Maxle? Heard of it. Guessing its like a maxle front 20mm with a qr type lever. What size are they in the rear and where do you get them?
Posted : 09/05/2010 8:48 pm
What frame are you running, and what drop outs does it have, as that dictates which fixing method you can use?
Posted : 09/05/2010 8:51 pm
Intense SS with 135mm dropouts. Came with adapter/spacer things for either qr, 10 or 12mm axles. I have a pair of wheels with Hope Pro 2's I will be putting on it. The rear is setup for 135mm qr. I was just wondering if I should beef it up a bit and how I should do it?
Posted : 09/05/2010 8:56 pm
You can get adapter kits for the standard QR hubs. If you can go 12mm then no real reason not to that I can think of. You'll need to get a QR for it too, or a bolt up axle.
Something like [url= http://www.realcycles.com/products.php?plid=m24b58s211p1344&rs=gb ]this[/url]
Posted : 09/05/2010 9:02 pm
