135mm hub with Deor...
[Closed] 135mm hub with Deore boost cranks - how bad is the chainline?
I'm in need of a cheap crank and chain ring for a 135mm QR hub frame. The new Shimano Deore M5100 looks superb value but it has a 52mm chainline (boost). However, Shimano claims it's ok for 135mm spacing https://bike.shimano.com/en-EU/product/component/deore-m4100/FC-M5100-1.html
Any ideas how the extra few mm will affect the gearing? Could Shimano claim the 135mm support by moving a spacer from the drive side to non-drive side?
Posted : 02/08/2020 8:42 am
If it's a bolt on ring like the picture there is no issue. Just put spacers between the ring and spider to adjust the chainline as you want it.
Posted : 02/08/2020 9:35 am
Shimano usually very very conservative on compatability not done but if was trying would do what you suggest on spacer hopefully someone who has done come along
Posted : 02/08/2020 9:42 am
It will be fine. You’re over thinking this.
Posted : 02/08/2020 9:49 am
@nixie good point about spacers between the ring and spider. I was thinking about moving spacers at the BB.
@bigblackshed i probably am overthinking!
Posted : 02/08/2020 10:26 am
A boost chainset puts the chairing in the same place as it would be using the big ring bolts on an old 2x non-boost chainset. Seeing as that's how a lot of people upgraded to 1x without issue you shouldn't have a problem. I upgraded one bike to 1x using a double chainset and the only difference compared to my other bike that was converted using a triple was that the alloy N/W chainring wore out after 1 chain rather than 2.
Posted : 02/08/2020 2:16 pm
Looks like that version is 4 bolt spider so you can use chainring spacers, the other deores are splined.
Posted : 02/08/2020 10:34 pm
