113 or 118 octalink...
[Closed] 113 or 118 octalink BB pls help?
I want to fit some old Shimano octalink cranks to a hardtail. 68mm BB shell. Is there a way of measuring to determine BB axle length? How critical is it to get it correct as 5mm difference equates to 2.5mm each side?
Posted : 23/01/2010 9:22 am
 StuE
What cranks are they ?
Posted : 23/01/2010 9:24 am
What model cranks are they?
The info for the required BB is often on the Shimano site
Posted : 23/01/2010 9:26 am
The logos are worn off. I think they are old LX before HTII. I'll check out the Shimano site.
Posted : 23/01/2010 9:29 am
113 for triple, 118 for single ring.
the 5mm is to get the correct chainline.
Posted : 23/01/2010 9:31 am
LX were a bit odd for [at least] one of the year models
121mm IIRC
the model number should be stamped on the inside of the arm where the pedal threads are
Posted : 23/01/2010 9:33 am
Model number is FC-M510....
Posted : 23/01/2010 9:40 am
Cheers uplink. What chainline will I be looking for 47.5mm or 50mm?
Posted : 23/01/2010 9:47 am
