11 speed quick link...
[Closed] 11 speed quick links for Shimano chains?
I've been happily using 9sp Sram ones on my 10 speed MTBs, but I don't think they're gonna cut it on 11 speed.
Any recommendations? Probably using a Shimano chain with new XT.
Posted : 19/10/2015 10:05 am
i just use the KMC or SRAM 11 speed ones
Posted : 19/10/2015 10:27 am
I have a KMC link on my road bike, with shimano 11 speed chain. Done about 500 miles so far, it seems fine.
Posted : 19/10/2015 11:01 am
Was looking at the KMC anyway, will go for those cheers.
Posted : 19/10/2015 11:04 am
THe KMC ones seem to work ok. You'll need a pair of pliers to get them apart though!
Posted : 19/10/2015 11:16 am
Why not just buy a SRAM chain? Comes with the link included. I can't be arsed with Shimano chains, purely for that reason.
Posted : 19/10/2015 11:20 am
I wasn't keen on the Sram 10 speed powerlocks and the Shimano chains are £10 cheaper.
Posted : 19/10/2015 11:25 am
I'm guessing the majority of new bikes come with Shimano chains (mine's got a 105 set-up so I got a Shimano chain as standard).
Posted : 19/10/2015 6:32 pm
So is it normal for these KMC links to be so tight that they won't actually pull into position on the chain?
I've given up and just used a chain tool instead for now.
Are you supposed to use a pair of link pliers to lock them into position? Not much use as a trailside fix like this.
Posted : 13/11/2015 9:09 am
Spin the cranks so that the link is on the top run of chain.
Stand on pedals.
The link will click into place.
Posted : 13/11/2015 9:10 am
They're both one shot not 'supposedg' to be reusable.
Posted : 13/11/2015 9:22 am
 cp
Stand on pedals.
This. Though you don't usually need to stand on the cranks... if the bike is in the stand just put the rear brake on and push on the pedal with your other hand.
I've only ever had this when opening the link again immediately after installation. After you've put a few miles on the chain, the normal squash the plates together and compress the link at the same time by hand trick always works.
I've found the old school chain tool rejoining method to be unreliable on modern (well, 10 speed) chains.
Posted : 13/11/2015 9:26 am
Stand on pedals.
Will try next time cheers.
Posted : 13/11/2015 9:27 am
[quote="chakaping"]I've given up and just used a chain tool instead for now.Is that a chaintool on the special shimano joining pin? Or a chain tool to push the part removed pin back into the chain?
If it's the former, carry on, it'll work fine until you next need to break the chain, then use a quicklink.
If it's the latter, you've probably knackered your chain and you are at a fair to middling chance of smashing your nuts on your stem when the chain snaps......
Posted : 13/11/2015 11:10 am
I think I've already discovered this.
Good job I went for a thrifty 105 chain.
Posted : 14/11/2015 7:56 am
Right I'm not going 11speed until decathlon start doing their £1.50 power links like they do with 10speed
I was umming and aging about it, but I'll stick with 10 for now!
Posted : 14/11/2015 9:58 am
I sort of wish I'd stuck with 10 speed TBH, it's been so much more hassle getting it working right.
Posted : 14/11/2015 10:02 am
I use KMC and even re use them on 11 speed Shimano chains. You need one of [url= http://www.chainreactioncycles.com/bbb-open-link-closing-link-tool-btl77/rp-prod47439 ]these[/url] to open and close the link easily.
Posted : 14/11/2015 10:33 am
really? Sounds more like poor prep than hassle. Upgraded one of my road bikes in the summer, took a couple of hours including new brakes, bar tape and so on.
Posted : 14/11/2015 10:46 am
[quote=chakaping opined]I sort of wish I'd stuck with 10 speed TBH, it's been so much more hassle getting it working right.
spacing is getting thinner and therefore the mech movement is less so it needs to be perfect as it has smaller tolerances
Still on 9 speed myself but all single ring these days
Posted : 14/11/2015 10:51 am
That's made me wonder about turning my salsa 11 speed as I'm using a 42 th expander and it shifts lovely.I thought 11 speed would just be a better range with the same quality of shifting.
Posted : 14/11/2015 11:17 am
I had high hopes after loving 11sp on my road bike.
11sp XT is much fussier about chainline than 10sp though, which has been the cause of most of my problems.
Posted : 14/11/2015 12:45 pm
Stand on pedals.
Just wanted to say thanks again, worked like a charm. Just gave it a crank in the workstand. Never too old to learn.
Removed my previous manually fixed link and replaced with the KMC one, so all should be hunky dory now.
*touches wood*
Posted : 15/11/2015 3:00 pm
