I have a xt 786 dynasis mech would these jockey wheels be ok on it?
https://www.wiggle.com/p/shimano-rd-m8000-deore-xt-11-speed-jockey-wheels
Posted : 13/05/2023 8:49 pm
Quote from Velonews:
Chains for 11-speed systems are around 5.4mm wide on the outside, vs. around 5.9mm wide for 10-speed ones, so that's 0.25mm narrower from the center of the cog tooth to the end of the chain pin on each side. That's not enough to likely even be noticeable in any difference in how it passes through the jockey wheel cage.
Probably, but the 11T Nukeproof ones come with the right spacers for 10 speed
Posted : 13/05/2023 9:22 pm
