10speed triple chai...
[Closed] 10speed triple chainset with 9speed mech?
Would a 10 speed shimano chainset work with 9speed chain /rear and front mech? I only ask this question because I can get one cheaper than the 9 speeed version. advice appreciated
Posted : 21/01/2012 9:23 pm
Yes
Posted : 21/01/2012 9:52 pm
 igm
As I understand it for Shimano the rear mechs and shifters (and cassettes obviously) have to match 9-to-9 or 10-to-10 because of different cable pull to change one sprocket. This is new for 10spd MTB stuff and is unlike the 7, 8 and 9 spd scenarios where you could get away with mixing shifters and mechs.
Everything else is interchangeable but may work a little better if arranged as Shimano saw fit.
As an aside, a 10spd MTB cassette and 10spd road shifter appear to require a 9spd rear mech to make them work - all Shimano parts that is. Bizzare.
Posted : 21/01/2012 10:54 pm
I read somewhere that the internal dimensions of the chain are the same as 9sp.
I understand the pull ratio is changed for MTB 10sp, but maybe on road it's the same as 9sp?
Posted : 21/01/2012 10:59 pm
Its only limiter screws...... You could widen the limits of a 7 speed to work on a 9 speed cassette. But the shifter has to have same number of clicks as there are cogs at the back.....
Posted : 21/01/2012 11:00 pm
I ran this for a few months before I completely went 10 speed. I did find a 10 speed chain ran slightly better as the 10 speed chainsets are designed for the externally narrower chains. As above 9 and 10 speed chainset have same internal width.
Posted : 22/01/2012 12:06 am
A 10 speed cassette requires a ten speed chain, a 10 speed rear mech requires a 10 speed shifter, a ten speed front mech will work with a nine speed shifter.
A ten speed cassette, chain, shifters, and mechs will run on a 9 speed crank and chainrings.
The internal measurements of a 9 and 10 speed chain are the same, the external measurements are different, thus a 9 speed chain can and does snag in the chainrings on a 10 speed cassette, this also means that a ten speed chain will run on a 9 speed crank and rings.
Think that covers it...
T
Posted : 22/01/2012 4:24 pm
 igm
Except when you mix road and MTB parts...
Posted : 22/01/2012 9:59 pm
