10mm difference, fo...
[Closed] 10mm difference, fork v frame difference
Is running a 120mm fork in a Bird Zero TR frame designed for a 130mm fork going to make a significant difference?
Opinions please...
Posted : 20/04/2018 11:54 pm
Run a bigger front tyre = problem solved.
Posted : 20/04/2018 11:58 pm
Thanks Matt, my view has always been that even without a bigger tyre it wouldn't make a massive difference, but since I'm looking at spending, I thought I would ask 😁
Posted : 21/04/2018 12:02 am
It's 1 centimeter.. If it's an air fork, build quality and weight of the fork, fork pressure and tyre pressure and type of tyre would make more difference than plus or minus 1cm.
I guess it would technically lower the handle bars very slightly, all things being equal, whether that's a good or bad thing I guess depends on how well the bike currently fits you,but it's a nominal difference.
Posted : 21/04/2018 12:09 am
It's not even 10mm once you take sag into account and it's not like all 130mm travel forks have the same A2C.
Posted : 21/04/2018 7:01 am
It'll probably steepen the head angle by half a degree. You could get some offset bushings for the rear to slacken it out again or just live with it.
Edit: ignore. The zero is a hard tail init? 😳
Posted : 21/04/2018 8:06 am
I think a fair few owners run 140, which I think I would enjoy over the current 130. I think my Yari need some tinkering to get them sweet though
Posted : 21/04/2018 8:08 am
By contrast I’ve just moved from a 130 Pike with 2.3 Minion to a 140 Pike with a 2.5 Minion, and I’m going to have to look at bar height as it feels a world away from how my bike handled previously. Am sure it’s just a case of adjusting the spacers but you may need to make some minor tweaks to get things perfect..
Posted : 21/04/2018 9:04 am
