10 speed and shadow...
[Closed] 10 speed and shadow clutch mechs worth the investment?
Evening guys,
9 speed front triple chain rings are in need of replacement and chain too. I can get an XT crank and triple 22.32.44 from CRC for around £116.
I'm wondering if this would be the time to make the jump to 10 speed? Costed it up around £260, for 10 speed cassette, xt shadow+ rear mech, xt front mech (I need a specific 10 speed right?) shifters, crank + triple rings, chain etc
I've read a lot about weak 10 speed chains, any truth to this? How good is the clutch mech at stopping chain chatter on rocky downhills? I'd be moving from Sram X9, to Shimano XT which I understand to be very crisper for shifting too?
Posted : 14/10/2014 9:14 pm
Chains are fine, clutch is excellent, your existing cranks and front mech are probably fine with new rings on
Posted : 14/10/2014 9:29 pm
I'd be really tempted to go 1x10 if I were you, it'll save you money and weight.
Could be worth fitting a 1x10 for now (pick it up in the CRC sale at the moment, you'll get a rear mech, shifter, chain, cassette and NW ring for less than a £100) and see how you get on, you can always swap the NW ring for a double/triple setup further down the line if you decide it's not for you and you'll only lose the cost of the NW ring (which you'll have no trouble selling on with little wear on it).
Posted : 14/10/2014 9:34 pm
I'm with darkslider. http://www.chainreactioncycles.com/shimano-xt-1x10-speed-drivetrain-bundle/rp-prod126347
use code comp for 10% off too.
I forgot to engage my clutch the other day and the chain slap was instantly noticeable.
Posted : 14/10/2014 9:53 pm
My set up is 1x10 Shimano slx clutch mech slx chain zee shifter raceface narrow wide chain ring all works brilliantly. Don't miss the 9 speed triple set-up what was on the bike originally.
Posted : 14/10/2014 10:32 pm
+1 for 1*10 with clutch mech. Depends on how big your hills and how long your rides are though
Ticsmon I thought of linking that bundle as I spotted it earlier while ordering my second lot of 10 speed gear for the downhill bike, but it won't let you select 104 bcd for the narrow wide ring so you might have to pick and choose your own set up. There are cheaper narrow wide rings available than the RF one too, my Superstar one has performed faultlessly.
Posted : 14/10/2014 10:34 pm
Thanks guys, i'd be really tempted by 1x10 or 2x10, but what kind of gearing/tooth setup would be best?
Current 22.32.44, with rear 9 speed 11-32.
Most rides climb around 1500 feet so I use the granny gear a lot on the steepest/longest climbs, and on some of the road sections to join up trails I do use the 44/9 to get some speed up.
Could 1x10 or 2x10 offer anything of a compromise?
That CRC bundle is a cracking price!
Posted : 14/10/2014 11:24 pm
I am using 32t Hope NW on the front and 11/42 with cassette extender on the back. Got me round Glentress Red with no bother at the weekend.
Posted : 14/10/2014 11:56 pm
