1 x and 2 x chainri...
[Closed] 1 x and 2 x chainrings...
Nothing particularly special about them is there? Like for instance, a 1 X narrow-wide thingy will fit a set of Turbine cranks which are currently 2x10?
And those 2x10s will fit an old M770 3X crank?
Just need to do a bit of swapping around so DezBJr can use my old 575.
Posted : 07/08/2017 11:56 am
Depends on the bolt circle diameter and spacing - as usual, there are a lot more 'standards' than there used to be!
Posted : 07/08/2017 12:17 pm
I'm sure they're both pretty standard 104BCD (Shimano definitely is).
Posted : 07/08/2017 12:22 pm
Apart from the bcd's/fitment methods as mentioned, if wanting to use 2x then having rings with the ramps and pins on really helps shifting however it can be done with normal rings
Posted : 07/08/2017 1:14 pm
OK, cheers. Sounds like my plans will work.
Posted : 07/08/2017 1:47 pm
It'll work as long as BCD is correct, done a few recently, 2 Shimano (old 3 cog XT and SLX) and an SRAM 2x10 - also for juniors bikes. 1x works brilliantly for them.
Posted : 07/08/2017 2:32 pm
 D0NK
just checking, you're not putting a narrow wide ring on a geared 2x or 3x system (with a F dérailleur) are you? jammage could ensue.....I'm sure you're not but just thought I'd ask.
But yeah as long as BCD is compatible should be fine, I run SS and 1x on old triple cranks
Posted : 07/08/2017 2:37 pm
If putting a n/w chainring on a 2x or 3x bike, you will probably need to manually move the chain on/off the n/w ring.
Posted : 07/08/2017 4:07 pm
No, the Turbines are going 1x , with a narrow-wide.
All sounds like it'll work and save a bit of dosh.
Posted : 07/08/2017 6:15 pm
