1 x 9 or even 10 ...
[Closed] 1 x 9 or even 10 set ups help please
Hello looking at a 1x 9 set up for North West England riding, been recommended as a training idea, I assume in my numptyness i need nothing more than
1 x cassette
rear derailluer
Chain
1 x chain ring
Crank arms.
Do i need a chain guide?
What is the best chain ring size?
Any advantage with 10 speed over 9?
Anyone running 1 x 9 for racing?
Thanks
Posted : 13/02/2012 9:04 pm
10s gets you an 11-36 cassette unless you go for that old 9s Deore 29er one that weighed as much as a coal barge, coupled with a 32t up front you'll get up pretty much anything. Spinning out on the flat might be an issue, but wasn't for me. You'll need a chain device, unless your only riding smooth trails. Superstarcomponents XCR works well.
Posted : 13/02/2012 9:33 pm
Unramped/singlespeed chainrings help a lot to keep chain on with the teeth been taller. I use that set up with a bash and N Gear jump stop and have never dropped a chain.
Posted : 13/02/2012 9:39 pm
Probably. You can either run a bash (BBG are tidy and good value) and a N-gear jumpstop, or a chainguide (Superstar are fine, and cheap)
32 or 34. You can get away with a 36 if you run the 11-36 cassette, or are strong, but with a 11-34 you'd be better off with a 32/34.
One more gear... the 10spd 11-36 is much lighter, as said.
Not me but I run 1x9 on both my trail bikes (32t and 11-34, 9spd, Superstar guide, on both) and, for me, it's ideal. On longer, tougher rides I sometimes miss a bail out gear but it's a rare occurence. The simplicity and robustness outweighs any shortcomings.
I run a Renthal SR4 ring on one bike, which is lovely, and an old middleburn on t'other. FSA do a very cheap DH ring down to 34t (see CRC) which is a bargain and well made.
Posted : 13/02/2012 10:13 pm
 mboy
It's always best... Unless you particularly enjoy stopping every few hundred yards to put your chain back on. Also, buy a quality one, they may look ridiculously overpriced but you'll be thankful when it "just works" which in my experience, the cheap ones don't do...
Personal Preference totally. I'd suggest anywhere between a 32 and a 36 depending on where you ride, or how strong you are. Any lower and you'd be better off running 2 chainrings, any higher and you need to learn to spin!
Yes, quite a bit. an 11-36 setup gives equally spaced ratios as on an 11-32 9 speed setup, but with the extra lower gear, it affords you a useful amount of extra gear range. About an extra 40% gear spread iirc, 1x10 gives you almost the same ratios overall (in terms of spread) as a 2x9 setup does!
Loads of people use a single ring setup for racing now, it's very popular amongst amateurs and pro's alike for XC racing now.
Posted : 13/02/2012 10:36 pm
You also need SHORTER CHAINRING BOLTS or a bashguard. I went for short bolts, which my local shop didnt stock so needed to mail order (charlie the bike monger) and also bought single specific ring.
I'm just building a 1x8 full susser and hoping 32 x 32 is low enough. If not I will be pushing.
Trying a £30 m part guide but fit not looking brilliant at the moment.
Posted : 13/02/2012 11:15 pm
I ran a 1X9 (36/34) for one of the Gorrick Enduro's and thought I was going to die, legs on fire, seeing stars - the whole 9 yards. On relfection, I loved the simplicity, but didn't have a big enough range of gears, and wondered why my lower back ached for 10 days afterwards...
Posted : 14/02/2012 7:53 am
Converted my training bike yesterday to 1 x 9 from 2 x 9. Superb, all you need is a new chainring, shorter chainring bolts and a chain device. Kept the old chain (as its shagged and a new one may not run on the old cassette and not even altered the length.
Gave it a good test up the steepest climb round here and the quickest downhill, its perfect.
Cost a total of £ 55 ish, its so quite now and looks cool.
No issues with gearing if you have a bit of fitness.
Posted : 14/02/2012 9:01 am
Given I ran a 1x9 setup for a while before single speeding the bike without a guide or tesnioner and not loosing the chain once you do not always need a guide. I rode the bike up at Thetford on the single track there so no rocks or freeriding there. Other places and riding styles may necessitate the need for a guide but it is not always essential. I also ran the 1x9 setup with the existing 9 speed ring. Give how easy it is to break a chain and fit a guide and fit a new chain ring I would set up you 1x10 set up take it for a test ride if it comes off head home and fit these two bits when the arrive in the post. No need to spend more than you have to is there.
Posted : 14/02/2012 1:20 pm
1x9 & 36tooth = hero! 😉
Posted : 14/02/2012 1:32 pm
cheers off to play
Posted : 14/02/2012 11:49 pm
Or lives/rides in East Anglia? 😛
Posted : 15/02/2012 12:06 am
Or train's more and harder than most on here and actually races 😉
Posted : 15/02/2012 9:18 am
My shop sells these:
http://www.comcycle-usa.com/Derailleurs-and-Shifters/Front-Derailleurs-10092/7398040-Origin8-Torqlite-UL/ProductInfo.aspx
It's a slightly more affordable option that I think people overlook.
It also comes in a seat tube mount option.
Enter code: 348376 for 20% off through March 31.
Posted : 09/03/2012 8:03 pm
10% **
Posted : 09/03/2012 8:21 pm
Top guide is fine for trail riding and xc but if you start messing about you will need a bottom guide as well unless you try the Shimano Clutch system which I have not yet because they don't do a short cage version.
See how you get on with a cheap top guide first because decent top and bottom guides are stupidly expensive for what they are.
Posted : 09/03/2012 8:33 pm
Changed to 1x10 last year and love it! Went 36t with 11-36 cassette, if I was trying a different ring size I'd go for a 38, find it a little undergeared on the road, but fine off road.
Only places I found it a bit of a grind this year were Margam, Dalby and Mayhem towards the end of the race in each case, never had to walk, just would have used an easier gear if I'd had one. For casual riding it's been fine everywhere I've been. Like the simplicity, saves weight, saves money, chain wears less!
I use a Superstar guide like the above, with a bodged seat tube mount as I've got a press-fit BB and they didn't do a proper seat tube mounted one when I bought mine.
Posted : 09/03/2012 9:04 pm
Straitline silent guide. Never drops the chain, and guess what? It's silent...
Posted : 09/03/2012 9:05 pm
I went 1x9 last autumn and love it - so simple and it's made me a better rider, both in pedalling and technique terms. Bash ring, N-gear jump stop, medium cage mech and shortened chain. 32t 11-34. About to offload this transmission to my spare (aka wife's) bike and 1x10 my Soul. I ride it pretty hard and off reasonably sized drops and have never dropped the chain so maybe that's less of an issue on a hardtail?
Njee, what cadence are you comfortable maintaining when racing and what do you spin up to when sprinting? I have the strength to haul 32-34 up pretty much anything but too much excess mass to go higher geared!
Posted : 09/03/2012 10:35 pm
