1 x 9 numpty quest...
[Closed] 1 x 9 numpty question
What do I need to do to go from 3x9 to 1x9? Just take the other chain rings off, leave the mech with stops screwed in and no shifter or do I need to get guides/special chain rings etc?
Posted : 22/02/2013 6:21 pm
You're on the money. You'll need to buy a little pack of stubby chainring bolts to attach the single ring to the cranks (eg E13 ones on crc for about £12) and then yes you can use your front mech as a chain guide.
Posted : 22/02/2013 6:26 pm
I think eventually you'll be better off getting a dedicated guide etc, but to try before you buy, fine.
Posted : 22/02/2013 6:32 pm
About 5 watts per kilo FTP.
Posted : 22/02/2013 6:36 pm
Yup, just that. I adjusted the front mech limit screws and dropped it a little on the frame so as the chain didn't rub on any of the rear sprockets, seems to hold the chain on well to.
Try your LBS for the shorter Chainring bolts, mine were £5
HTH
Carl
Posted : 22/02/2013 7:03 pm
It's also recommended (not necessary) to shorten the chain.
Have fun!
Posted : 22/02/2013 7:05 pm
Hadn't considered the chainring bolts, what about rear much length? - shorter along with shorter chain?
Posted : 22/02/2013 7:51 pm
 br
[i]What do I need to do to go from 3x9 to 1x9?[/i]
Be fit, or ride in flat places?
Posted : 22/02/2013 7:52 pm
I've ran the existing mech till its fubar then replaced it with a short cage and shortened the chain to suit
Posted : 22/02/2013 7:57 pm
