1 x 11 = chainline ...
[Closed] 1 x 11 = chainline question
I am converting my non-boost 2013 Giant Anthem from 3 x 9 to a new 1 x 11 set up. I'm ordering some new 175mm cranks and believe I need a 49 to 50mm chainline ? Sound about right ?
Would a boost 53.4mm chainline work fine on a non boost wheel ? or would this put too much lateral tension on the chain ? measuring the chainline using the middle chaingring on the 3x9 seems to put it around 53mm.
Posted : 10/05/2020 5:14 pm
 pdw
I'd expect boost chainline on a non-boost wheel to be awful. It'll be noisy in lowest gears and jump down the cassette if you back pedal.
Standard chainline is already quite a long way outboard of the middle of the cassette. Non-boost chainline on a boost wheel works nicely as it puts it closer to the middle of the cassette.
Posted : 10/05/2020 7:07 pm
Why not just use your existing cranks? Tune chainline with spacers if you feel the need.
Posted : 10/05/2020 7:32 pm
