1 bike, 2 sets of w...
[Closed] 1 bike, 2 sets of wheels. different freehubs, Will this work?
First world problem I know, but I have two gravel bikes. one 650b and another 700c. One is an Sram XD rear but and the other a Shimano freehub. If I had for example, and 11-34 cassette on each of them would the wheels be interchangeable without any shifting issues?
In reality one is Ultegra 11-32 and the other SRAM 10-42 force. I would like to be able to run the 700C (shimano) wheels with fast tyres between the two. What are the chances of this working?
Posted : 09/01/2021 4:39 am
I have the same on my Diverge - Specialized wheels came with XDR freehub and 6 bolt disc mount whereas my Roval wheels are Shimano and centrelock. I can swap the wheels without making any adjustments
Posted : 09/01/2021 7:35 am
@dovebiker cheers for that...
Posted : 09/01/2021 8:47 am
I do that on my ebike(different hubs), dt swiss centrelock, hope pro 4 was a straight swap, hope pro 4 (xt)and spec roval (sram xg) I needed some disc spacers to match the hopes to the roval but now a straight swap
Syntace.
https://www.ebay.co.uk/itm/284064511062
Hope (thicker - pick size ,
https://www.sjscycles.co.uk/brakes/100-mm-hope-6-bolt-hub-disc-spacer/
Posted : 09/01/2021 9:35 am
Simple answer... Maybe.... maybe not.. You don't often find 2 different rears that will give all the gears, heck, it's not always you find 1 wheel that will ๐Ÿ™‚
Only answer is "try it and see"
Are they both the same hub standard- width and axle diameter?
Posted : 09/01/2021 10:06 am
I found that using different brand hubs meant the brake spacing was slightly different, only a tiny amount but it was enough to need to re position the calipers to stop constant rubbing every time I swapped the wheels. Not the end of the world but an annoyance.
Posted : 09/01/2021 12:08 pm
