1-11 or 1-12 on a 2...
[Closed] 1-11 or 1-12 on a 26” - Can it be done
Might have been touched on elsewhere but can’t find anything on search but looking to (if possible) switch to a 1-11 or 1-12 on my 26”
Currently running Crank Bros cobalt rims with Shimano 9 speed
Any help / advice appreciated
Thanks in advance
Posted : 20/01/2020 11:23 am
Shimano 11 speed MTB cassettes use the same freehub as the 9 speed you already have.
Posted : 20/01/2020 11:25 am
Gearing is not wheel size specific
To a point. You might need a bigger chainring with smaller wheels; if your frame can only take a 32t single ring (which mine does) it might be a bit low-geared on a 26er.
Posted : 20/01/2020 11:27 am
 StuF
You'll struggle to find a 26" wheel with a microspline hub unless you have it custom built
Posted : 20/01/2020 11:28 am
Short answer, yes it can.
Specifics depend on brand preference and budget.
Posted : 20/01/2020 11:50 am
11 speed is simple. As mentioned above check the max size front chain ring you can run, especially on a full suspension bike.
You did not mention the crankset that you are currently running but many can be single ringed although you will probably need shorter chain ring bolts.
All you need except the front chain ring and bolts linky
Posted : 20/01/2020 12:29 pm
Doesn't the NX 11-50 12 speed cassette fit on a standard freehub?
Posted : 20/01/2020 12:33 pm
Running NX 11 speed on my 26er Spesh Stumpy Evo.
32 tooth narrow wide ring, NX shifter and mech, Shimano cassette with 42 tooth bottom gear. Some random 11 speed chain.
Works perfectly.
Could do with a slightly lower bottom gear still as its hilly here in mid-Wales, but that would mean a new mech.
Posted : 20/01/2020 12:50 pm
Other half has 1x12 on her 26” pivot. The rear mech is starting to look a little long for the wheel but all runs fine!
Posted : 20/01/2020 12:54 pm
Sure, my Rocket26 is 1x11 with the M8000 XT drivechain. Good old 32x11-42 on a traditional freehub, but I've Hope hubs so could trivially swap the freehub to use newer Microspline or XD cassettes.
Posted : 20/01/2020 12:58 pm
Doesn’t the NX 11-50 12 speed cassette fit on a standard freehub?
Yeah. And the SX.
Posted : 20/01/2020 1:44 pm
Thanks for all the input so far , as I previously said currently running 1-9 XT with XT crankset and 32T ring
Moving forward will probably go XT or maybe XTR preowned in 11
Anyone rate the Sunrace MX8 cassette ?
Posted : 20/01/2020 7:47 pm
Yes it can...done it on a Frog 69 - NX eagle cassette and GX Eagle mech and shifter. Shifts well.
I'm thinking of updating my 26" hardtail and likely to go GX Eagle...
Posted : 20/01/2020 9:20 pm
