Looking at getting some new brakes but can't get a post mount rear caliper in XTR.
I know standard disc size for post mount is 160mm, but will rear IS run 140mm?
Help please
Help please
its just IS rear isnt it? and that should be (with no adapter) 140mm?
edit:on the rear only
Thanks
If you fit a specific rear caliper then you run a 160mm rotor. However if you fit an IS front caliper on the rear then you run a 140mm rotor.
