XT Brake issue
[Closed] XT Brake issue
[#3742980]
Ordered and fitted a pair of XT brakes from rose bikes. The rear is fantastic but the front is piss poor. Not very powerful and horrendous squealing - in fact the squeal is ridiculous. I had to shorten the front hose and bleed it - any ideas? I've tried a re bleed and re-aligned it - still the same
Posted : 05/03/2012 7:01 pm
If reach, grab and feel are good but performance is poor then it sounds like pad contamination to me.
Posted : 05/03/2012 7:04 pm
 cp
Could be pad contamination, could be poor mount alignment. Have you ever had the fork mount faced?
Posted : 05/03/2012 7:27 pm
Mine was a bit like that - I just cleaned the disc with brake cleaner and rubbed a load of mud into the front disc and pulsed the lever while riding along and it was fine.
Posted : 05/03/2012 8:55 pm
Check you don't have a leaky brake (pulling to lever), mine had to go back to maddison for repair. Still haven't heard back 5 weeks later?
Posted : 05/03/2012 9:42 pm
Is there a way to tell if the pads have been contaminated?
Posted : 05/03/2012 11:17 pm
Yeah, they have no power and squeal like pigs.
Posted : 05/03/2012 11:19 pm
Take your pads out, give them a good wipe and then give the pad surface a light sand until the dry material comes through. This takes very little sanding with a bit of sand paper. Put them back in and see how you get on.
Posted : 05/03/2012 11:21 pm
 jruk
I managed to get some oil on my XT pads but saved them by...
- stick them in a caliper that you know is working
- ride with the brake on to get them reallllly hot
- poor water on them
- ride with them on again - the water etc creates a paste
- repeat 2/3 times and they were fine
If that doesn't work get a £7 set from superstar, they work a treat.
Posted : 05/03/2012 11:28 pm
swap the pads to the rear but clean the discs with IPA so you don't contaminate the rear pads.
Posted : 05/03/2012 11:42 pm
Bloody bleed nipple leaking!!!! New pads time
Posted : 06/03/2012 1:07 am
To Mafiafish, i'm guessing they've gone back to Madison via a shop, and you'll probably find that they've been credited for a new one without realising it(need to look on transaction history as they don't appear to notify you about it as well).
Posted : 06/03/2012 8:25 am
