WLAN down - any ide...
[Closed] WLAN down - any ideas?
[#3587143]
Wireless connection seems to be down today. red light on WLAN other all green in router. Main connection ok but can't run anything wirelessly.
Tried turning the router on/off (high tech solution) - any other ideas from anyone with tech skills?
Posted : 20/01/2012 12:18 pm
If you have a static IP BT are experiencing issues in the UK.
Should be fixed as of 45 mins ago though, reset your router.
Posted : 20/01/2012 12:32 pm
so a wired connection to the router is ok but wireless not?
does it even show if you search for available access points?
if not I'd say the receiver is probably bust?
Posted : 20/01/2012 12:34 pm
Whoops sorry didnt read your op very carefully!
Posted : 20/01/2012 12:39 pm
It could be the BT issue. I have a speed touch router and all the lights (power, ethernet, DSL, Internet) are green with the exception of WLAN which has been red all morning.
Can use the main computer but no wireless connections anywhere.
wwaswas - if I understand your ? correctly - yes the link shows on devices and looks like wireless is working. But when you try to access anything wirelessly I get the message about not being connected.
Could be surfer is right for my region as well?
Anyway, thanks for replies so far.
Posted : 20/01/2012 12:40 pm
try scanning to see if any of your neighbours have suddenly plumbed in a WLAN router that's broadcasting on the channel you use?
I had a similar issue before - a BT HomeHub (sp) from a neighbour seemed to be very aggressive, switching channels on my router fixed the problem
Posted : 20/01/2012 1:47 pm
I tend to avoid these questions now because of the amount of useless crap people spout makes them useless but are you confident the wireless connection is being made from your laptop? Assuming you're talking about a laptop?
Does the little wireless icon say it is connected?
Do you know how to confirm you have an IP address and check you can ping the gateway?
Posted : 20/01/2012 1:48 pm
Red light on WLAN still showing but connection restored somehow. Bizarre!
Anyway cheers for help.
Posted : 20/01/2012 2:58 pm
