Winter Tyres x2 or ...
[Closed] Winter Tyres x2 or x4?
[#3274173]
Getting winter tyres fitted to Mrs Sinatra's Peugeot 107 tomorrow, we live in Scotland and she needs to drive all over the countryside for her work. Getting 4x4 is not an option just now.
Question is though whether to get just the front tyres done or get them all round.
Any thoughts?
Posted : 24/10/2011 10:13 am
2 would work fine, if she gets scared easily then 4!
IMO a 107 with snow tyres would be better than most 4x4's anyhow.
Posted : 24/10/2011 10:14 am
I'm looking forward to it, I reckon it will be a blast!
Posted : 24/10/2011 10:22 am
I'd say 4... anecdotally 2 can lead to the back of the car sliding around even as the front maintains its grip. A sliding rear could still be enough to cause some trouble. Edited to say I get scared easily!
Although tempting to fit 2 on a fwd hatch 'cos most work is done by the front wheels, what about corners, bends and roundabouts where the rear will step out?
Just fitted 4 winter tyres to the wife's fwd car. This winter's fronts will be next winter's rears so the long term cost is the same.
Right, 2 it is then! 😉
Posted : 24/10/2011 10:23 am
depends whether you trust the missus to react correctly when the back end steps out - or will she just bin it into a ditch.
I'd be fitting 4.
Posted : 24/10/2011 11:00 am
Only fitting two is not recommended.
You'll have different grip levels f&r. Unless she practices hanging it out on snowy roads to get a handle on things the first time she'll notice it is when she's in a ditch (or worse).
There's little point in the front gripping/steering if it get's overtaken by the back.
Winter Tyres for a 107 should be pretty cheap so go for all four. 🙂
Posted : 24/10/2011 11:08 am
She would react by blaming me!
I seem to have missed the boat this year on tyres. Best proce locally I could find was £55 fitted. Seem to have got more expensive as we get closer to cold weather
Posted : 24/10/2011 11:10 am
4 is the way to go if you can afford it. I couldn't last year so only have 2 and i can got about fine. I just need to remember the back is not a grippy and is more likely to slide out than the front. My hope was to add another 2 this year but have no money again and use the car less as i can walk to work now so will just be driving carefully again this year. This year my rear tyres only have about 4mm of tread so i think i may be pushing my luck a little more if it gets really bad.
Posted : 24/10/2011 11:11 am
Wait 'til the clocks change and frost arrives, the price will rocket.
Edit: Just checked, the tyres we bought 2 weeks ago are up a tenner each already.
Posted : 24/10/2011 11:12 am
According to my cars handbook, all 4 tyres should be changed if any are to be used at all.. bit tricky as I'm skint and need at least 2..
Trouble is, if in a crash and your not following the manufacturers recommendation, your potentially liable, it's worth thinking about.
Posted : 24/10/2011 11:32 am
 5lab
tread depth will only really make a difference when its wet, and 4mm will be enough to clear all but the very deepest puddles at high speed. Road tyre tread isn't aggressive enough to really make any difference on snow (not saying winter tyres dont work better, but imo they work better due to the compound differences more than the tread itself)
Posted : 24/10/2011 11:42 am
Read this on another forum I use.
[img] http://www.winterhighland.info/forum/file.php?2,file=7742 [/img]
I'll be refitting my 4 winter tyres next weekend 😉
Posted : 24/10/2011 11:49 am
 hora
Depends. If you drive like a tool on bad conditions (when I say 'tool' I mean drive like you would in summer) then no winter tyre would save you from ice/bad conditions.
If I lived in Scotland I'd buy 4 winter tyres.
Here in Manchester I've got two snowProx's to go on the front (FWD).
If I owned a RWD car I'd fit 4. Why? I can handle the back coming out at low speed - all I seek is 'increased traction on the bad bits. I wont be going fast.
Posted : 24/10/2011 11:53 am
franksinatra - Member
That's pretty good value, isn't it?
A bloke at work was quoted £180/tyre for his Skoda Yeti. And that was with a 25% discount offer that they currently have running!
It's only a 1.2 TSI, but has 225/??/17 tyres on it!
Posted : 24/10/2011 11:55 am
Michelin recommends you spend more money with them shocker...
Posted : 24/10/2011 11:56 am
EDIT: Funkydunc beat me to it...
Posted : 24/10/2011 12:00 pm
 hora
stumpy was that a main dealer by chance?
Bro in law had a tyre replaced on his car by the main dealer even though he didnt ask for it and had measured the treads a week before (he carries a gauge around with him- no idea why).
Posted : 24/10/2011 12:01 pm
I bought 4 budget winter tyres so I didn't actually spend it with them.
And whilst they may be budget they're a whole load better than summer "performance" tyres, they also don't wear out as quick in the cold.
 SnS
Just had 2 Yokohama W. Drive V902a's fitted at weekend.
Was considering getting all 4, but it's damned expensive so just got the drive wheels done ( FWD)
I have a 'reserved' driving style at the best of times which gets even more reserved during winter.
Kind of looking forward to seeing if they're any good.
Chris
Posted : 24/10/2011 12:16 pm
A word of caution, check with your insurance company. In the past I've always told them that I've swapped tyre's and there's been no further queries or charge from them (no questions whether it was 2 or 4) but this year I was specifically asked if I'd fitted all 4.
Posted : 24/10/2011 12:24 pm
Personnally I don't see why the insurance company should be informed, as it isn't a modification, as (well in my case) I will/should be following what my manufacturers recommends in the car handbook, not bolting on a go faster exhaust or wider/lower than recommended wheels.
Another thread on this, had some saying their insurance company charged them extra for doing it.
As winter tyres are to enhance the abilities of the car in winter conditions, how can this something the insurance needs to up the policy to protect against...
Posted : 24/10/2011 12:32 pm
Winter tyres are a performance enhancement and help your car go quicker, so therefore the risk of a big accident goes up.
Just like any other performanc mod in that way.
Posted : 24/10/2011 12:35 pm
I got told it was because you are more likely/frquently to go out in worse conditions there is a greater chance of you having an accidents therefore we are going to charge you more.
pretty poor reason if you ask me.
Posted : 24/10/2011 12:38 pm
Probably a mixture of all, but insurance co's will justify anything if it means they get more money 🙂
Posted : 24/10/2011 12:40 pm
BUT no, winter tyre enhance your car ability to grip in un-sound conditions. If you drive like a tool, that no more likey to happen with winter or summer tyres on.
Tell me what other performance mod's come recommended in your car handbook from the manufacturer as standard?
This I think is more likely, and would totally agree with +1
Though I don't see how this can be a justification really, As you've taken extra precautions against the weather conditions, so why should you not be out driving?
EDIT: FD yes.. that is more likely to be simply the case
Posted : 24/10/2011 12:43 pm
 SnS
Due to a similar thread a year or so ago where one of the STW's got quoted something like an extra £240 to fit cold weather tyres to his Laguna estate, I checked before having mine fitted - Rang on a Sat & had to ring back Sunday - No problem. ...I wasn't asked whether it was 2 or 4 I was fitting ( This is with Aviva).
Chris
Posted : 24/10/2011 12:46 pm
Took a punt last year - I got 4x Conti Winter Contacts off ebay for £100. all with +5mm of tread
Seller: save_on_tyres_direct
Recommended and dealt with replacement of 1 tyre with sidewall damage within 24hrs.
Posted : 24/10/2011 12:54 pm
 SnS
Found the above mentioned insurance increase mentioning STW member on Auto Express
http://www.autoexpress.co.uk/news/autoexpressnews/260503/winter_tyre_ko_as_big_freeze_hits.html
excerpt from : "Meanwhile, some insurers are failing to spot the benefit and are raising premiums. Auto Express subscriber David Gana, from Oldham, Lancs, said Frizzell told him the “modification” of winter tyres for his Renault Laguna would hike his premium by £230. And www.singletrackworld.com forum contributor Swalsey was surprised when he rang Admiral to see if his winter tyres would attract a discount. “It quoted an INCREASE of £22!” he fumed.
Chris
Posted : 24/10/2011 12:56 pm
excerpt from : "Meanwhile, some insurers are failing to spot the benefit and are raising premiums. Auto Express subscriber David Gana, from Oldham, Lancs, said Frizzell told him the “modification” of winter tyres for his Renault Laguna would hike his premium by £230. And http://www.singletrackworld.com forum contributor Swalsey was surprised when he rang Admiral to see if his winter tyres would attract a discount. “It quoted an INCREASE of £22!” he fumed.
BBC had an article about this last year. I think the consensus was brain dead call centre staff were the issue.
http://www.bbc.co.uk/news/business-11969958
Posted : 24/10/2011 1:01 pm
Yep, I've come across these folk before hence the call this year however I'll have to defend the bloke from Churchill who when queried whether there would be an additional cost said "you're making the car safer, why would we charge you more"
Posted : 24/10/2011 1:15 pm
 5lab
i can see though that winter tyre users could be more likely to crash than people who don't. I won't be fitting winter tyres, as I live on the south coast, and for the 3 days a year it's snowey, I just won't drive. Someone might live next door to me but be yomping up and down the country, and gets the tyres because when its snowing, he needs to get to work over the downs.
He's doing the safe thing by fitting the tyres, but he could be more at risk by doing so. Its the same as fitting better brakes to a car, or improving the handling. In itself, it makes the car safer, but in doing it, you're now in a catagory of drivers more likely to crash
Posted : 24/10/2011 1:23 pm
Not convinced by that. Maybe more likely to have someone slide into the back of you...
Posted : 24/10/2011 1:26 pm
hora - Member
Nope, "STS tyre pros" in Letchworth. I think that the Skoda dealer were quite reasonable when he enquired, although in the end he got them from Camskill & the dealer is fitting them for £7.50 a corner.
Posted : 24/10/2011 1:27 pm
Actually, just a point for others reading this who maybe are considering winter tyres. -
They're not just for snow, they're great in wet/cold conditions [I'm in Scotland].
Posted : 24/10/2011 1:29 pm
 5lab
my point is, it can make your car safer, yet statistically make you more likely to crash at the same time. If you drive in inclemental conditions whilst I sit at home in front of the fire, you're more likely to crash than I am.
I don't know that it does work this way, but this is why modifications to suspension and brakes increase your premium whilst making you safer
I take your point about sitting at home vs being on the road.
I think in part the suspension/brake premium issue is due to boy racers and/or Impreza driving man-children who haven't grown out of driving like arseholes, being the ones who tend to engage in pimping activities...
Posted : 24/10/2011 1:36 pm
x4 ordered and due to be fitted tomorrow.
Bring on the winter!
Posted : 24/10/2011 3:36 pm
 hora
In winter the only thing that scares me (no not black ice) is other drivers on the roads.
Posted : 24/10/2011 3:50 pm
I would definately recommend them. On that note, I have made a mistake and ordered the wrong ones so am selling a pare two. They are 215/55/17 Toyo Snowprox, they get good reviews. Based in Scotland but would send. I have put them on the For Sale section. These are good tyres which I think are now out of stock. Let me know if you would like them.
Posted : 24/10/2011 3:53 pm
 hora
Michelin Alpins are consistently voted the highest (occasionally beaten by Conti winters).
Posted : 24/10/2011 3:56 pm
The insurance increase issue was last winter. It is highly unlikely anyone will see their premium increase due to fitting winter tyres anymore.
Posted : 24/10/2011 4:13 pm
Any thoughts on Dunlop Sp Wintersport 3D, quoted @ £83 per wheel fitted.. found them slightly cheaper online but only slightly and still need to get em fitted...
Posted : 24/10/2011 4:15 pm
We've just ordered 4x avon ice touring tyres - they come across fairly well rated across the board even against the big boys and they're cheap as chips. I'll be sticking to my rain tyres and 4wd, and just not driving like a loon.
Posted : 24/10/2011 4:24 pm
