Saddle when descending even the steep stuff? I never drop my saddle on my HT trail bike, I see it as a bit of a challenge with the seat up.
Bike Forum
Who doesn't drop their...
Posted 1 year ago #
I usually drop hither, thither, somewhere and here. But never there.
Posted 1 year ago # -
me.
HT doesn't have a QR so got used to it. On the 5 I never think to drop it !
drop where ?
Maybe the stuff you are riding is not that steep then OP? As surely there comes a point where gravity/physics take over if you not hanging off the rear wheel?
you can hang over the wheel without dropping the post though
True...bit awkward though.
can get over the saddle without it and I often don't bother. Does make it a bit easier/more secure though.
it's getting back over an un-dropped saddle that usually catches one out.
agreed
in fact I thought that on the chute at McMoab !!
I have a hole in my thigh where a seat rail tore me open after ripping out of the seat. That was going over the bars on some steep stuff on AbbaZabba. I have recently fitted a Joplin and I'm gonna use it.
Drop it on the Soul on stuff like Jacobs Ladder and The Beast, but not a lot apart from that. Maybe Cavedale too.
Jamie, What's steep for you? Some stuff I ride is pretty steep but not to the point of being stupid. I have ridden the red DH at Fort William, Ben Lomand etc on my HT with the seat up and for the best part was fine. Of course there are times I become a bit unstuck and have tumbles but who doesn't? I do drop it on my FS now and again though.
"bit of a challenge with the seat up"
Indeed it is when the terrain gets steep or rough. But if racing or time trialling or whatever, I have no inclination to stop and mess about with it so just have to gulp and do it.
Trail riding yes, I drop mine 3" for every decent length descent. It just makes the bike that much easier to manoeuvre through fast corners, roll-downs and little drops without fear of being bumped off by the saddle.
On the hardtail with carbon seatpost fitted, no - never. But then I'd use the FS for real hooligan stuff.
Depends how long and how steep really, on the CRC marathon in september i did it after going across the top of the mountain as the drop down was very rocky and slippy plus i was bloomin knackered and could barely get back on the bike without falling off again!
Never feel the need to drop mine,if I decide it's too steep for me then I still wouldn't ride it with the saddle down.
Always for any decent length of DH. I cant really cope with it if its up my arse even if the trail isn very steep I like to get all over the bike.
I'm with coatsey, I use a bolt-up collar and I can't be arsed with it. When I've done it, I can see the benefit but I just don't. Then again, I'm sh1t down technical stuff so maybe I should. There's no way I'm going to bolt .5kg of post-dropper onto the bike tho' (weight weenie, but you should see me climb).
Depends on the bike, on my Anthem I never do as it's a twin bolt clamp, on my 456 I do if I can be bothered, but has to be steep as I'm too lazy most of the time!
Posted 1 year ago #
It's not getting over the rear wheel that's a problem, it's getting back on again that I struggle with. Especially if my shorts hook up on the seat as well. Nightmare.
Always messing about with saddle height, might get a dropper eventually, but they're expensive. Especially as if I get one and I like it, I'll need one on the other two bikes as well. Also, it plays merry hell with your matching finishing kit!
Quite a lot to be honest on both my HT and my FS
I started running the seat slightly lower all the time - a little harder on the climbs but hardly ever need to drop it now.
never drop it!
me - hardly feel the need ever to drop the post - only once in the last few years and that was on my first slippy wet descent of cavedale in the peak - now i can ride it 'up' ok... i do mince and go slow n steady ! Plus re shorts snagging - i mostly use tights / 3/4s and i dont snag - sometimes i do catch my endura baggies... most 'proper ' rides i go for the lycra...
to date / hellvellyn - rosthwaite / seathwaite / top o'skiddaw / walna scar / garburn / cadair idris / snowdon / the ben alll done this year with post up...
i do appreciate seeing all the threads re joplins etc - ones i have seen on the trail have been 'tempermental'... i am intrigued by them but maybe its just another 'rad fad' (TM) to go with the image... and my baggy shorts...
paul
Always drop mine. If you don't need to drop it on steep stuff, it's either not steep, or you're not going fast enough
My saddle never moves.
Saddle height is a compromise between legs getting a workout / being lazy and being able to get off the back, should I need to, but unless its near vertical, I stay sat of hover over the saddle anyway.
Don't brake on steep things and you won't go over the bars.
I've started trying more stuff with mine up, and it's yet to cause me any real problems, and it seems like a useful skill... but it's nothing like as effective as having it down, so I won't be changing over.
househusband - Member
On the hardtail with carbon seatpost fitted, no - never. But then I'd use the FS for real hooligan stuff.He he he... You double gnar bastard!!
if I don't drop the saddle while descending the seatpost usually gets bent pretty quickly..
I probably ride with my saddle completely slammed far more than at full height!
at the start of this winter I left it at full extension for about a month (unusual for me, but I was riding very familiar or fairly untechnical trails all month) and it was fine everywwhere including steep chutes and I still managed to jump doubles etc, with a little style... But any of the more fun descents/technical riding was nowhere near as much fun (or as fast) as I was forced to ride far more within my limits.
eg. on flat pedals you simply cannot get as much grip with the saddle at full extension as when it's out the way, you can't pump as well or pick the bike up and you are way less stable when it gets hairy!Posted 1 year ago # -
...pants on a first date?
...kebab with excitement?
..aitches when talking to lower class people?
Nope, my saddle never moves.
....kids off at the pool?
Ah another blessed thread that mistakes dopping your saddle as being to allow you to get your weight back rather than down......
Posted 1 year ago #
Topic Closed
