What/where replacem...
[Closed] What/where replacement ST BB
[#3932034]
again fixing an older bike, just taken the Square taper BB out and found it's marked (and measures) as a CT91 116x68 but I can't find a 116mm ST BB on CRC/Wiggle or Merlin.
Does one exist, or should I just try and use a 115mm one or go up to a 118?
Sheldon site suggest the chain line can be between 47.5 to 50, so I'm thinking technically the 118 one is the way to go, but 115 is sooo close....
Posted : 01/05/2012 2:25 pm
115 is only 0.5mm less each side. Unless you're VERY short on chainstay clearance, I suspect you'll be OK
Posted : 01/05/2012 2:29 pm
thats a good point, though to be fair the 118 will only be 1 mm further out then, so @ 48.5 well within the chainline limits
(hadn't thought to split the figures - cheers for the heads up)
cheers
Posted : 01/05/2012 2:41 pm
