pics if possible..just wanting to decide what to get
thanks
Bruce
Bike Forum
whats everyones 29ers weighting in at? bike and frame weights please?
Posted 4 months ago #
pegasus sub 30, swift +30, no idea really
HTHPosted 4 months ago # -
Pace RC129, singlespeed, Rebas, 23.5lb. Never weighed the frame itself.
My old Inbred 29er was over 31lb, but then its frame was almost 6lb, it was running an Alfine hub, had handlebars made of steel... It certainly could have gone on a diet, rode nicely though.
Copped a feel of someone's new Carbon Niner the other week, 22lb despite not particularly light wheels on it! Very nice...
swift 28lbs ish.
Chumba HX2 in medium, 26lbs with mid range kit and 1x9.
Weighed it when it was 2x9 so maybe 1/2oz lighter now
XL Mythic Paradox with Micro Ti 44's & Halo freedom wheels, Formula Mega's with 203 rotors, XT crank, X9 rear mech etc etc. 32-33lbs
Scott scale carbon in large. Put on lighter wheelset bor rims on am classic hubs, SIDS, old xtr in 2 x 9 set up, formula r1 brakes and a few other bits comes out at 19.5lbs with race tyres on..
Large Niner RIP9 current build with dropper and chunky pedals, 29.5 lbs.
Not sure what the frame weighs, but circa 6.5-7 lbs I guess.
My Scandal is about 26lbs with a less spangley build.
Swift was 27lbs when I last weighed it. That's "ready to ride" with seat pack, pump etc. attached.
Ridgeline 2 * 10 around 24.5 lbs
Yelli Screamy 1 * 10 (now with Reverb and SLX brakes) 28/29lbs
On-one carbon sample with a lefty/rotor cranks/xtr on is 20.4 lb(frame 990g) & my carbon race with lefty/xt is 22.3 lb (frame 1320g)
salsa selma singlespeed with carbon forks 18lb 10oz, with fox F29, 20lb 7oz
Frame weight just under 4lb with the EBB fitted.
Jones steel diamond Frame and unicrown fork, 26lb 2oz with 29er wheels, 29lb 5oz with cheapo fat front.
@bigdugsbaws - They are both lush !
My Swift, weirdly, weighed 29 lbs last time I weighed it, it has had some minor changes since this (crap) pic so might be a bit lighter now.
Scott Scale Carbon, 20.5lb in winter spec, drops to 19.7lb with summer tyres etc.
1.8KG IIRC, no idea built up.
Here doing some real riding.
Inbred, SS with carbon forks, SmallBlock8's on TN719's on Surly SS hubs, Thomson seat post & stem, carbon bars & Ti saddle...24lbs. Swap forks for Maxle Rebas, wheels for TN719's on Pro2's, & SLX 1x10...26.5 lb.
Don't know what frame weighs.Posted 4 months ago # -
Niner EMD 27/28 lbs, wheels and v2's are heavy, could probs shed a couple of pounds from that but don't notice it riding so ......
Uploaded with ImageShack.us
Turner Sultan, all up, ready to ride, Sasquatch frame (23"), 30lbs.
I can't believe how
ironicheavy the Swifts are.Not sure how heavy the ScandAL is.
This one at 27lb.
This one at 21.5lb.
Rigid, 1 x 10
As a S/S, 19.5lb.
3.5lb frame
28lb Bike (with 'proper' tires on mind)
Giant XTC 29er. Comes in at 26.5lb as weighed by LBS the day before i bought it.
O-O Ti29er.
About 18lbs with those tyres on (Stouts)
Dips into the 17lbs with summer boots on.
Ti post, 230g aluminium bars, middleburns on UN54 BB for now. XTR brakes, superstar superlight hubs, charge spoon with cromo rails.
There's 100g to be saved from the BB with a Ti axled one, and I could use a lighter chain as well but I like the reliability of the PC1.
Custom ChiTi frame from XACD 3.4kg.
Full weight 11kg.
Lynskey Ridgeline 29VF - frame's 3lbs 12 oz. Weighed it at the weekend at 23lbs 6ozs with Rebas, 1x9 & DT240/355 wheels. Got some FRM/BOR wheels being built that'll take it sub 23lbs.
Kona Unit ss with rigid Salsa Cromoto - 23lbs.
This is my ti frame from XACD in china it,s just over 29 lbs ready to ride with alfine boat anchor
[img]
[/img]
TooTall - Member
I can't believe howironicheavy the Swifts are.TO be fair, I it's 'Swift' as in the bird rather than as in 'fast'. Mind you it doesn't feel heavy to ride.
I can't believe some of the claimed weights though - that I'm more suspicious of...
Scandal about 22lb
Yeti about 26lb
Mine comes in just under 21 lbs on my scales. It's a custom Ti frame, designed to be a bit more beefy than most, running with alloy bars, M4 brakes and fairly hefty tyres so lots of potential to drop weight if I wanted to...
No idea?
Swift, low t mid 20's I guess as it's:
SS
Rigid (OK not that light as its steel)
XTR cranks and E-13 chainring
Alloy bolts where possible
Ti bolts where thye're not
Few remaining steel ones where they're not Ti.
S-works tyres
Hope hoops (ok, not that light)
Thompson stem/post (ok, not very light)
Specialized phenom saddle
EA70 bars
Foam grips
Mini X2 brakes.
Aligator rotors.Posted 4 months ago # -
New On-one Scandal, frame apparently weighs 3.9lbs (i never checked but i think someone on here did), This build 24-25lbs, my scales are crap so could be a little either way.
My Swift - 21lbs 05.
Medium Swift
DT Swiss XRR Forks
XTR M960 modded cranks
American classic wheels
EC70 bars and EA70 finishing kit
New XT brakes with the icetech rotors
erm, Schwalbe tyresGoes to 23lbs 12 with a set of Reba's on it.
Giant Anthem = 21.5lbs, not bad for a ally FS 3x9 setup.
Giant Anthem X 29er frame (L) with Fox Float RP23 Boostvalve
Fox F29 FIT RLC forks, 15QR thru axle and tapered steerer, 100mm travel
Giant FSA tapered headset
XTR SIS gear cable set
Shimano BB71 Press-Fit Bottom Bracket
FSA K-Force Light XC Chainset MegaExo
XTR pedals
Thomson masterpiece seatpost
Ritchey WCS Carbon Flat Bar
Ritchey WCS 4Axis Matrix Stem
Hope mono mini pro’s in Team Issue Green, Ti bolted
X0 Twist grip changers
X0 Rear mech with KCNC jockey wheels
XTR front mech
KMC SL chain
160mm Ashima rotors, Ti bolted
PG990 cassette
American Classic hubs (15mm front, QR rear)
DT Super Comp spokes
Stans Crest rims
Racing Ralphs 2.25s UST front and back
Fizik Arione saddlePosted 4 months ago # -
Mine's currently being built up - fag paper maths says 17lbs
Niner Air Carbon
Niner fork
Enve wheels, stem, bars and post
Di2 1x10
Mt8's
Some silly light tyres that will be replaced ASAPPosted 4 months ago # -
That is some serious wedge
Reply »
You must log in to post.
