What tyre pressures
[Closed] What tyre pressures
[#457073]
A mate of mine.....Tinsy.....wants to know what tyre pressures you all run on your full sussers, he's too embarrased to ask himself
Posted : 08/04/2009 10:57 am
2bar any more is road bike teritory
Posted : 08/04/2009 10:59 am
Ha ha... Toomanybikes... you know its really for you..
Posted : 08/04/2009 11:12 am
25-30 on the front, bit more on the rear
Posted : 08/04/2009 11:25 am
What grumm said
Posted : 08/04/2009 11:26 am
Tinsy, I run 40 at both ends, means i can ride faster
Posted : 08/04/2009 11:27 am
40 - 60 psi depending on terrain.
Posted : 08/04/2009 11:31 am
35-40 on the back, 30-35 on the front.
Posted : 08/04/2009 12:14 pm
I use the minimum on my sidewall and also my weight. 35-45psi.
I do notice my front tire sliding too much or rebounding badly if the wrong pressure is used
-probably from my weight/riding position as the rear never slips.
Posted : 08/04/2009 12:19 pm
Tyre pressures depend on how light you are and how heavily you ride. Given that I only weigh in at 11 stone and tend float over stuff I get away with 25-27psi up front and 27.5psi in the back.
Posted : 08/04/2009 12:23 pm
About this much:
Posted : 08/04/2009 12:25 pm
35-40 - 15st+
Posted : 08/04/2009 1:37 pm
 taka
fuk me i run 45-50 on ma dh bike thats why i bounce 10ft whem i land 😉
Posted : 08/04/2009 1:40 pm
What started out as my mate taking the pee out of me, has actually got me thinking of dropping my pressure a fair bit for tonights ride. going to give 35 rear, and 30 front a try...
Posted : 08/04/2009 1:42 pm
Be careful tinsy - low pressures are good for traction, but poor when cornering hard (tyre rolling off rim etc) and increase in pinch punctures.
I would rather be a touch high on pressure, and not have a problem...
Posted : 08/04/2009 1:44 pm
What matt_outandabout said (the picture), I never use tyre gauges, I just run what feels right when I squeeze the tyre 🙂
Posted : 08/04/2009 1:45 pm
fair enough, maybe I will just drop a few psi at a time and experiment then.
As I did the last post a big question mark popped into my head about the front tyre rolling a bit...
Posted : 08/04/2009 1:49 pm
what chvck said but then a little bit less for the front on rocks
Posted : 08/04/2009 1:59 pm
Drop the pressures - low = more grip and much less pinging and richocheting off roots n rocks.
When you get down to a pressure that gets you pinch flats every now and then, first of all try and stop whacking into stuff so hard, and if that doesn't work then you have indeed gone too low on pressures.
The photo is good - squishy like an orange, not hard like an apple!
Posted : 08/04/2009 2:13 pm
