What new Forks for ...
[Closed] What new Forks for my Hemlock?
[#1334614]
Looking to replace some 140 Pike Air forks on My Hemlock.
Considering Rockshox Rev Dual Air 150's (my favourite choice at mo), Magura Thor or Lyrik Coil U-Turns. Fox 36's look nice too but are very expensive!
Quite like the idea of adjustale 160 forks but not sure I would need that much travel and they are quite a bit heavier too. Also I wonder if longer forks would make the Hemlock more stable on Downhills?
Posted : 17/02/2010 12:13 pm
i'd say the pike-air-140's are just about perfect already...
(the hemlock is very Dh friendly as it is, maybe try a shorter stem or something?)
Posted : 17/02/2010 12:44 pm
Thor are improved for '10 and are much cheapness at On One
Posted : 17/02/2010 12:48 pm
I've just ordered the Team Rev U-turns for my Hemlock to replace the Pike u-turns. Mostly to lose a bit of weight, but also because my mechanic wants the Pikes for one of his bikes...
Posted : 17/02/2010 12:49 pm
Wee work of caution about the new Revs. Was at Learnie the other weekend and a pal fell sideways with his bike when he stalled at a rock feature. A sharp rock dented the lowers so much the fork is effectively ****ed and new lowers are £225. Ross isn't a big heavy chap either. I guess they are light, but have they maybe gone too far? Fine if you don't crash or ride rocks I suppose.
Posted : 17/02/2010 1:00 pm
The missus is about to stick 2010 revs on hers. (edit, she's said as much 2 posts up!)
Depends what you're using it for, but from my experience of riding Hemlocks, I'd far prefer a 160mm fork for extra stability/stiffness/slackness/rockeating ability. Or you could try the Revs with the K-nine offset headset cups if you have a 1.5" version as Cy's been using (see the Cotic News page)
Posted : 17/02/2010 1:09 pm
Be using it for a bit of everything really from Chilterns/Cotswolds singletrack to trips to Peaks, Wales and the Alps. My current Pikes have been brilliant but the stanchions are getting very worn and marked plus it has seen a lot of action too!
Those Thors at On-One look a bargain but would not need the lockdown to 100mm thing. Hmm so much choice wondering if a 1.5inch version of forks is worth buying and if they would fit on the Hope 1.5 reducer headset I have?
Posted : 17/02/2010 1:21 pm
