What Hope caliper (...
[Closed] What Hope caliper (mono mini)?
[#1590995]
For the black and gold mono mini, what caliper number do I need for a 160mm front?
And am I right in thinking that this would be the same as a 140mm rear? Looking at a poorly written ebay listing.
Can't see the info I need on Hope's website.
Cheers,
Simon
Posted : 10/05/2010 7:38 am
Well, I run the E4 and a mate runs the M4. With those the following applied
number 3 185f 165r
number 5 165f 145r
number 8 205f 185r
number 6 boxxer specific.
HTH
Posted : 10/05/2010 7:46 am
No.5 for 160mm front, and is the same as 140mm rear.
Posted : 10/05/2010 7:48 am
Cheers, I guess I'll need to find to a new rotor as well then. Hmmm.
I thought the mono-mini did 140, 160 and 180 🙁
(EDIT: I think I'd better ask Hope!)
Posted : 10/05/2010 7:50 am
You're correct. The IS mount calipers are as you say; the PM (9.74) are 160, 183 and 203mm with appropriate adaptor. The 165, 185 and 205mm discs are for the original (silver, two-piece) Mini and M4 calipers.
To confirm: you need a No.5 Mono Mini caliper to match a 160mm front disc (or 140mm rear).
Posted : 10/05/2010 9:33 am
Nice one I'll ask the seller 🙂
Posted : 10/05/2010 9:42 am
