What headset?
[Closed] What headset?
[#917524]
I'm getting a Dialledbikes PA,it's a 19 inch frame and the headtube is 120mm long,looking at buying some 2nd hand forks but the steerer is cut to 180mm.The stem i want to put on has a stack height of 50mm.....So this leaves me only 10mm for the headset,does anyone know of a really low stack headset that will fit? Does it matter if the top of the steerer is below the height of the top of the stem? Please help.
Posted : 02/10/2009 6:04 pm
The top of the steerer needs to be a couple of mms below the top of the spacer/stem. Realistically you have almost 15mm for the headset. FSA will be fine.
Posted : 02/10/2009 6:22 pm
 nuke
CB headsets are the lowest I know at 21mm stack height iirc. Thomson stem, for example, is 40mm stack so you could get away with that. As hairchested said, FSA stems have low stack heights
Posted : 02/10/2009 6:24 pm
Cheers for the replies, :-).
Posted : 02/10/2009 6:52 pm
