what front mech for...
[Closed] what front mech for a 2010 stumpy ??
[#3080320]
Ive just bought this 2010 stumpy full suss frame and i need to buy a front mech for it but im not sure what fits it.
it looks like the bolts to the rear swing arm but i cant see anymechs that mount this way on the crc site??
any ideas people??
cheers
steve
Posted : 24/08/2011 4:05 pm
The spec list for the 2010 Stumpy FSR Elite (& Expert) reckons it's:
Shimano M660 SLX DMD top swing, dual pull
I can probably take a pic of the one on mine later & post it on here if that would help?
I think DMD is direct mount.....?
Posted : 24/08/2011 4:53 pm
Specialized tend to use an E-type front mech with the mounting plate removed.
Direct mount are conventional swing where as FD-M660 is a top swing like an E-type. So my money would be on one of these with a little modification -
Posted : 24/08/2011 5:07 pm
Here's the spec list for the 2010 Stumpy FSR:
http://www.twospoke.com/forum/f54/specialized-stumpjumper-fsr-expert-2010-a-4036/
I found this; it's the 2011 10-speed SLX front mech instead of the 2010 9-speed, but the third pic down shows is annotated as dual pull, direct fit.
http://www.rutlandcycling.com/24310/Shimano-SLX-M660---M661-10-Speed-Mountain-Bike-Front-Mech---2011.html
My front mech definitely isn't e-type; it's fitted to the carbon FSR with press-fit BB, but was transferred from the original aluminium frame that was warrantied.
Posted : 24/08/2011 5:17 pm
thnaks for the replies so far.
the one listed for the bike is this
Shimano M660 SLX, DMD, top swing, dual pull
looking at the picture of the one above i think where the two bolts are on it is where it would bold to my frame like my 09 enduro.......
cheers
steve
Posted : 24/08/2011 6:26 pm
A couple of crap images - rubbish phone camera, lit with my spokeshirts light...
Looks similar to the one fitted to that frame above, definitely has those three bolts along the lower edge.
Posted : 24/08/2011 7:02 pm
renton, the one in your picture is as I thought it would be. It is an e-type mech with the mount plate removed. See the two allen head screws in my picture? You undo those, remove the plate and screw the mech directly to the frame.
A Shimano direct fit mech looks like this -
And that definitely isn't going to work.
Posted : 24/08/2011 8:07 pm
 Chew
I used the one in Mister P's photo. Unscrew and remove the bottom ring, and then bolt it onto the frame.
Posted : 24/08/2011 9:29 pm
Its the DMD E type / s3
Same as my epic. Although ive got a 2011 for 10 speed front mech shouldnt make a jot of difference*.
http://www.chainreactioncycles.com/Models.aspx?ModelID=69485
* I may be wrong Plus mine is Sram
Posted : 24/08/2011 9:45 pm
