VBA help please
[Closed] VBA help please
[#3934556]
And this is why I hate VBA, because Im soooooo crap at it.
So a big favour to ask of any VBA gurus...
Could you start me off with some code to do the following please:
Set up:
There's a column of 290 ids in colA of sheet1
Next to that an empty columnB in sheet1 to receive a pasted value
Take the first ID from row 1 of ColA in sheet1 copy and paste it into a cell (same cell everytime) in sheet2, wait for a vlookup to populate, run a goalseek, copy an output value in sheet2 and paste value in first cell of columnB of sheet1,
NEXT
copy second ID from colA and repeat, pasting output value in second cell of ColB. Repeat for 290 rows.
Beer tokens available! 🙂
Posted : 02/05/2012 10:44 am
Not knowing the specifics of the calculation you're carrying out, I may be oversimplifying this, but would a user defined function not be a better way of achieving the same result?
That way you could just call it in a formula in col B of your spreadsheet and copy it down to all the relevant rows.
The process of copying a value to another sheet just to return a calculated value before moving it back again sounds a bit clunky to say the least.
Posted : 02/05/2012 10:49 am
Because a goalseek is required to solve for the output (big model) it needs to run as a macro, there's no static solution, otherwise I could have used SCENARIO
Posted : 02/05/2012 10:51 am
VBA offers a goalseek method, which can in turn refer to a cell range so pretty sure you could still do it in a function.
http://msdn.microsoft.com/en-us/library/aa195749(v=office.11).aspx
Posted : 02/05/2012 10:56 am
youve lost me.
I have a large model that's populated from data sources that are selected by comparing with an id code. Once populated, a goal seek is run to provide a solution by iterating an unknown variable. Once solved for a target that unknown variable is then extracted and stored.
Then another set of data is brought into the model based on a new ID and on again.
Running 290 goalseeks is not something Id want happening in the back ground to keep a UDF fresh, I want to control when it runs.
Posted : 02/05/2012 11:01 am
You wouldn't be running 290 goalseeks in the UDF - I'm proposing you set up a user defined function to run the Vlookup and Goalseek that you're currently proposing to do by copying a value between two worksheets.
You can then call that UDF on demand for individual IDs to return your "unknown" variable.
Posted : 02/05/2012 11:05 am
I can do that already, I want a bit of code/macro to run all 290 in a batch. I need the VBA to change the inputs before each running of the goalseek and then to store the output in a table.
Posted : 02/05/2012 11:08 am
Sub testicles()
' bingo
For x = 1 To 290
Sheets("Sheet1").Select
Cells(x, 1).Copy
Sheets("Sheet2").Select
Cells(x, 1).Select
ActiveSheet.Paste
Range("F5").GoalSeek Goal:=400, ChangingCell:=Range("C3")
Cells(5,6).Copy '[whatever the output cell you want to copy]
Cells(x, 2).Select
Selection.PasteSpecial Paste:=xlPasteValues, Operation:=xlNone, SkipBlanks _
:=False, Transpose:=False
Next x
Posted : 02/05/2012 11:22 am
you might want to use activecell.pastespecial xlPasteValues
rather that just activecell.paste
otherwise if you have a formula in sheet1colA it would get messed up
Posted : 02/05/2012 11:29 am
Public Sub mark()
For x = 1 To 5
Cells(x, 1).Copy
Cells(x, 1).Select
ActiveCell.Paste
Range("A3").goalseek Goal:=1000000, ChangingCell:=Range("A2")
Cells(1, 3).Copy
Cells(x, 2).Select
ActiveCell.Paste
Next x
End Sub
ive created a dummy setup to get the syntax right, but when I play this macro
"Object doesnt support this property or method" when it gets to "ActiveCell.Paste"
EDIT ahah cross posts, will try again
Posted : 02/05/2012 11:34 am
edited
[i]I can do that already, I want a bit of code/macro to run all 290 in a batch. I need the VBA to change the inputs before each running of the goalseek and then to store the output in a table.[/i]
I know - I was trying to point out that copying and pasting values between different bits of the spreadsheet isn't the best way of returning the value you're after as you could encapsulate that in a function.
Code like Reggie Gasket's above will give you the means to move through your table. The user defined function would be called within that with the ID from the relevant cell as the parameter.
Posted : 02/05/2012 11:35 am
needs to be Activesheet.paste, not activecell
Got it, you legend reggie xxxxxxxxxx
Sub goalseek()
' goalseek Macro
' Keyboard Shortcut: Ctrl+w
For x = 1 To 5
Cells(x, 1).Copy
Cells(1, 1).Select
Cells(2, 1).Copy
Cells(x, 2).Select
Next x
End Sub
Posted : 02/05/2012 11:41 am
invoice is in the post...
Posted : 02/05/2012 12:54 pm
are payments in beer VAT exempt?
thanks again.
Code running fine, although I might need to put some kind of error catcher in there for if there is no solution to the goalseek.
Now just waiting for the client to send me the unlock password to be able to drop the code in the model, at the moment I have to run it from outside. Another reason to have it set up this way, as I cant embed UDF etc in the host model.
Posted : 02/05/2012 12:57 pm
put
On Error Resume Next
on the line before the goalseek code
that way if it can't find a solution it just carries on anyway, like a stubborn child/wife/roadie/singlespeeder
Posted : 02/05/2012 3:21 pm
great will try that. Thanks
Just received an unlocked master model, so trying to drop the code in now. I feel like Will SMith in Independance Day 🙂
Posted : 02/05/2012 3:25 pm
