Not bothered about fashion its keeping the bonce warm that matters.
Bike Forum
Troute Mini?
Posted 1 year ago #
Trout
Wondering if you can profer some help/advice re a dodgy circuit board/chip mounting on a Magicshine battery pack?Mate has just bought a s/h unit and we have traced the fault to one of the chips, seems to have can be wobbled to get a connection.
Is this repairable?
Can a new circuit board be aquired easily? It has the ID LYH/8232/2S
BTW who is your mate/battery supplier? Know a few folk who are looking for backup packs.
Thanks in advance
JH
Posted 1 year ago # -
Does the mini come with fur trappers hat as standard?
The battery guy is smudge.
Trout, guess the 'other' light is now lanquishing somewhere unused (cough)................
Hi Trekster,
If you want to post me the battery I can check it over for you and replace the protection circuit if that's where the fault lies.
Email in my profile.
Smudge
Cheers will pass info on, getting the dreaded access denied message from works server
We have proded around the little battery circuit board and when one of the chips is prodded/squeezed we can get a light/battery charge indication. Battery pack is sitting with 5v in it and we can get 8v charging by wiggling/manipulating chip.
I Have just repaired ( hopefully ) a Bastid with an intermittent fault it turned out to be the connectors have gone faulty
Put a new cable on both battery and light and so far it s doing OK .Posted 1 year ago # -
I had a problem with the switch on my bastid not working properly.
I took it all apart and it seems that the big green rubber bit has what can only be described as a nipple on the inside that pushes on the switch. This had got stuck beside te switch meaning it worked itnermittently.
Put it all back together and it's fine. Won't be using it much now though now I have a LLPosted 1 year ago #
Topic Closed
