Trekbuddy mapping, ...
[Closed] Trekbuddy mapping, any experts in or pointers to a not too techy guide/resource.
[#2339471]
Want to experiment with phone as GPS idea, see Google maps as quick way to a dead battery and want OS maps in any case, preferably 1:25000
Android phone - check
trekbuddy app - check
maps - not yet
As far as I can see you need to create the maps yourself by taking screenshots from multimap, or other sites, then stitch the lot together and calibrate. Seems so much of a ball ache I can't believe there isn't an easier way. Ideally would like maps of peak district and south yorks generally, is there an online resource? Maybe I've missed something, my brain is a bit addled from staying up to watch the cricket.
Posted : 05/01/2011 2:58 pm
Bump for the evening shift.
Posted : 05/01/2011 9:26 pm
Mobile atlas creator. Installed it last, selected my area, my zooms, my map - multimap UK. Hit create atlas and away it went.10mins later I stuck the folder on the phone and away it goes. Seems good.
Posted : 05/01/2011 10:33 pm
There is a much easier way. I will write up or send a link in a minute after Indiana Jones has finished!
Posted : 05/01/2011 10:38 pm
What you want is Viewranger. Available for Android, and all the maps you could want, UK, France, America...
Accept no substitute.
Posted : 05/01/2011 10:45 pm
This is only a quick guide, so sorry if I have missed anything out! Written very simply to try and avoid confusion (sorry if it is very long-winded!)
[u]Mobile Atlas Creator part[/u]
Download Mobile Atlas Creator from:
[url=[url= http://sourceforge.net/projects/trekbuddyatlasc/ ]http://sourceforge.net/projects/trekbuddyatlasc/[/url]]Mobile Atlas Creator link[/url]
Think you need to unzip it first, then go to wherever you have unzipped it to and click on the Mobile Atlas Creator icon.
You should get a screen similar to this:
but yours will be just showing a view of the world.
In the top left hand corner of the screen there is a list under the ‘Map Source’ button. It lists all the different open source maps available. For UK OS maps you want to select ‘Multimap UK OS Map’ from the dropdown list.
Next you want to scroll on the map to the area that you want to create a map for. To select an area left click and drag over an area. A red box will appear highlighting the area you are selecting. You select different scales (or zoom levels on your phone) by checking the boxes in the ‘Zoom Layer’ box. Lower numbers give you large areas at low resolution, higher numbers give the more detailed maps but obviously will increase the number of tiles downloaded, and therefore will be larger file sizes. Personally I use Zoom levels 14 and 15 which corresponds I think to 1:10000 and 1:25000 OS Maps. Layer 16 gives the same detail as 15 but zoomed in.
Leave the ‘Layersettings’ box as the default settings.
The ‘Atlas Content’ box is the name you will see the maps stored to. By default the name given to your atlas is ‘Unnamed Atlas’. Make it something recognisable (e.g. Sheffield). You can rename the atlas by pressing F2 or right clicking and selecting rename. The namebox is the name given to the individual layers (i.e. Sheffield 14, Sheffield 15), where the number correlates to the zoom layer (the numbers are added automatically, so for the above example I would put Sheffield in this box.
If you are happy with the area you have selected and the zoom levels, press the ‘Add Selection’ button and you will see your maps added to the atlas in the ‘Atlas Content’ box.
In the next box ‘Atlas Settings’, make sure TrekBuddy tared atlas is selected from the dropdown menu.
Finally press the ‘Create atlas’ button to create your maps. A dialog box will appear for a few seconds (longer for larger maps), and will tell you when completed successfully.
You now have your maps downloaded to your computer, now you need to send them to your phone and put them in the right folder.
[u]Phone part[/u]
Connect your phone and mount as disk drive.
Open the Mobile Atlas folder on your PC. Look for the atlases folder which should be in the same place as the Mobile Atlas Creator launcher icon you used at the start. If you open the ‘atlases’ folder you should see your folder that contains the maps created a minute ago (e.g. Sheffield in my example).
In a new window on your PC find the folder on your phone for TrekBuddy stuff. It should be in your SD card folder, labelled ‘TrekBuddy.’ Go into this folder and you will find a ‘maps’ folder. Open this folder and copy across the maps folder you found for the step above.
The maps are now on your phone! Unmount your phone in the same way you would take out a USB stick, wait a few seconds for the phone to check the SD card and then open TrekBuddy. If you are wanting just one zoom layer you can use ‘Load Map’ from the menu and select just one of the zoom layers. Alternatively you can select ‘Load Atlas’ which will load all the zoom layers and allow you to quickly change between the zoom layers. You can do this by selecting your atlas and then selecting the file labelled ‘cr.tar’. If you can’t figure this out I can pull up some screenshots but think this post is already getting pretty long!
There are more options for customizing TrekBuddy such as using a CMS which gives a graphical output of your route in real time but this involves some more copying of files. For now the above will allow you to play around with TrekBuddy to see if you like it. There are other similar programs out there each with different views on what makes a good offline GPS program. Each has its advantages, discussed a few days ago:
[url= http://www.singletrackworld.com/forum/topic/ordnance-survey-maps-on-android-phones/page/2#post-2149532 ]Android GPS war[/url]
Let me know if you get stuck, but hopefully you shouldn’t! Again apologies if this is over-simplified but hopefully it will get you up and running! 😀
Posted : 05/01/2011 11:21 pm
Wow, thanks for that. I now realise I had missed most of the atlas creator stuff as I hadn't actually tried it since I had read some of the very early stuff on the trekbuddy forum when it was still very fiddly and faffy. I'll give it a proper go now, cheers.
Posted : 06/01/2011 12:07 am
Mobile Atlas Creator is currently not available as a download, does anyone have one for Windows they could get to me somehow?
Posted : 28/03/2011 1:15 pm
Got a load of OS 1:25000 and 1:50000 if you want them. I use them on my nokia phone with trekbuddy.
A good mate of mine sorted them I don't know how he did it, but they are great.
mail me at eastham8 at aol dot com and i'll put them on a DVD and send them to you.
Posted : 28/03/2011 1:21 pm
@Vortexracing - will do if no-one can let me have a download of the software so I can make my own 😀
Posted : 28/03/2011 6:12 pm
Download here: http://www.onlinedown.com/detail/104451.htm
Posted : 29/03/2011 9:57 am
Official download is back: http://sourceforge.net/projects/mobac/files/Mobile%20Atlas%20Creator/
Posted : 30/03/2011 4:59 pm
Sadly the OS mapping is now missing from Mobile Atlas Creator. Can anyone help me out? (Esp. with Peak District/Dales/Lakes)
Thanks
Jules
Posted : 21/04/2011 12:36 am
There isn't a simple, legal way to do it. OS are pretty protective. It's not too bad if you just want a specific area for a ride but creating a large area is too much faff. In the end I bought viewranger which works so much better. I rarely pay for software so that is saying something. I can send you a referral code that gets us both some free maps (enough for a few rides)
Posted : 21/04/2011 7:46 am
Thanks Nick,
I've already got Viewranger for my own region, was looking for a free way to extend my map coverage. Must stop being a tightwad!
Posted : 21/04/2011 8:27 am
You can add free maps like bing and opencyclemap to viewranger. Not as good as OS but pretty good for free. Increase the map cache, change the map source to online, scroll over everywhere you need at a couple of different zooms while on wifi at home. The maps will then be stored on the phone for offline use.
Posted : 21/04/2011 8:39 am
OS Maps are still there from what I can see.
Latest beta version is [url= http://sourceforge.net/projects/mobac/files/Mobile%20Atlas%20Creator/MOBAC%201.9/Mobile%20Atlas%20Creator%201.9%20plain%20beta%202.zip/download ]here[/url]
It's brilliant. I wouldn't use anything else, if my phone was waterproof and lasted more than 5 hours with the GPS on.
Posted : 21/04/2011 10:46 am
