Tips for removing a...
[Closed] Tips for removing a rounded allen bolt?
[#1977756]
Trying to change the bent mech hander on my old Hustler. It has three small 2.5mm allen bolts holding it on. One of the bolts has rounded. I have tried using a Torx tool, a selection of different allen keys and am in the process of filing down a 3mm key which is very tedious using a leatherman. I do not have a drill at my disposal.
Any ideas?
Posted : 10/09/2010 12:22 pm
drill/bolt extractor would be best option but otherwise hammer a torx bit into it
Posted : 10/09/2010 12:25 pm
Go and beg for help at the local bikeshop!
Take cake and look desperate and embarrassed.
Posted : 10/09/2010 12:26 pm
Cut a slot with a hacksaw and use a screwdriver.
If you don't have a extractor tool.
I have epoxied in a sacrificial allen key before.
Posted : 10/09/2010 12:35 pm
If you have a dremel or similiar, cut a slot with a small cutting wheel. Has the advantage of also putting a load of localised heat into the bolt.
Posted : 10/09/2010 1:06 pm
a brand new hgh quality allen key might have undone it previously, but not now you;ve used a torx head. any of the sugestions above are fine, epoxy in a sacrifical allen key, cut a slot and screwdriver it, drill it, or try and hammer in a slightly larger allen key.
Posted : 10/09/2010 1:24 pm
used a dremel to cut a slot - cheers for the tips!
Posted : 10/09/2010 3:32 pm
Can you get a small multi tooth socket on the outside of the bolt you will need to tap it on with a hammer, has worked for me many times.
Posted : 10/09/2010 3:50 pm
I use a larger Spline tool, tap it in with a hammer, then remove after soaking the bolt in WD40 or the like, It damages the spline toll slightly but it's quicker then cutting a flat head screw it it.
Posted : 10/09/2010 4:14 pm
A shaped C4 charge.
Posted : 10/09/2010 4:18 pm
Can you hammer in the next size up torx bit? Works sometimes depending on the size of rounded hole
