This DX light is cr...
[Closed] This DX light is crap.
[#892829]
Having followed all the chat on here i bought a DX light for my helmet as a back up to my Vision 2. It seems like a nice torch but 900 lumens?
My Hope's are 480 lumens and there is no comparison, in fact my mate turned with a Lidl £5 light that wasn't much worse. Is mine a duff un?
I can't believe people can use these on there own if this is as good as they gets.
Posted : 24/09/2009 8:09 am
I run a trailtech 13w HID (dont know the lumen output sorry) and next to my mates DX light, there is no difference, infact I would say the DX is slightly brighter.
Posted : 24/09/2009 8:17 am
i think you've got a duff'un. I went out with my mate last night who has a hope HID and mine if anything is slightly brighter?
Posted : 24/09/2009 8:29 am
Have you got it on full blast or the lowest setting? Which light did you buy? My DX light has 3 light outputs, a flash and SOS, but most of the links on STW show a light with 2 settings...I can't speak for that one, but unless you shell out £400+ on a light, there isn't anything out there that can give a better brightness - perhaps some with a more usable spread, etc. but none that go any brighter without spending serious cash.
Was the battery charged?
Horses for courses, one of my riding mates refused to buy the DX light as he believed something that cheap couldn't work so well...ended up with a very expensive light (which is good, but doesn't seem any better than the DX light) that pumps out a similar light output and light spread.
It says SF-15 on it and using the button on the end it is on or off only, is this right?
Posted : 24/09/2009 8:33 am
 daim
@Mugboo - Sounds like you have bought the wrong light.
My DX light is easily brighter than my old Lupine Edison 5 HID. (with the Lupine on full 16w)
is this: [url= http://www.dealextreme.com/details.dx/sku.25149 ]http://www.dealextreme.com/details.dx/sku.25149[/url] what you bought?
Posted : 24/09/2009 8:35 am
You press the button on the back to turn it on and off (so it clicks) but press it with less force to cycle through the different light outputs (no click)
Posted : 24/09/2009 8:42 am
Hope not i followed a link on here where someone kindly posted up which torch/battery/charger/plug adapter.
[url= http://www.dealextreme.com/details.dx/sku.22567 ]SF-15?[/url]
Posted : 24/09/2009 8:43 am
 daim
Oh, you bought a torch. Sorry mate, I thought you were referring to the DX 'bastid' light (which is awesome).
Doh!
Posted : 24/09/2009 8:50 am
Strange. When i first tryed the torch at home it would only start in flasing mode. Last night on its first outing it must have only used low power.
Sat here in front of the computer i've got it to cycle through its modes so dodgy switch or more likely user error!!!
Thanks for your help.
Posted : 24/09/2009 8:55 am
Its this one by the way
Posted : 24/09/2009 8:56 am
Fail
Posted : 24/09/2009 9:11 am
Is it [i]really[/i] crap though? For $30?
Posted : 24/09/2009 9:15 am
[url= http://www.dealextreme.com/details.dx/sku.12060 ]SKU12060[/url] is the one to go for. I tried a 2-mode version & the low setting was a bit too low to be usable. It also failed completely...but only after my little lad switched it on to high & left it standing on the lens on the floor.!!!
DX exchanged it with no questions.
I found that the Li-Ion cells need a few cycles to get to full strength also, one of the cells I use loses a load of power once it starts to drain. Both of the 12060's that I use are easily as bright as the Hope 10w HID I used to have. Mine have been in regular use for nearly a year now.
Once you get the hang of the gentle push on the switch you'll have no problems.
Posted : 24/09/2009 9:34 am
You'll never get 900lm out of that torch anyway - it's just not possible with that combination of LED and battery.
In fact if it really lasts 2.5 hrs on max, then you'll only be getting about 300lm.
Posted : 24/09/2009 9:57 am
Now i've worked out how to cycle it, Doh! i'm sure it won't be crap but if you want a fast answer on here just try slagging off DX lights...
Posted : 24/09/2009 10:15 am
Or bigging up Superstar!!
What happened to superstars led light ?
Posted : 24/09/2009 10:17 am
 daim
@saladdodger
Octopus Light?
Posted : 24/09/2009 5:15 pm
If the switch seems dodgy, take off the back cap, and you can see two little holes in the switch endy bit that let you unscrew it. Unscrew it a little, then screw it back up tight and make sure it is quite nice and snug.
You need something to stick in the holes, obviously a pin spanner or something made for the job is perfect, but if you haven't got one, use something random and pointy - I used the leads from a multi-meter, cos they were what I happened to have handy. If it is a little loose, you get weirdy stuff happening with the button - I know this from experience thanks to my urge to take things apart and my lack of care when putting it back together.
Joe
Posted : 24/09/2009 5:21 pm
I have the same torch as the OP. It's brighter than either a mate's Hope (Vision 2) 2xHID light and my Trustfire P7 (that gives 2 hrs). This torch doesn't give anywhere near 2 hrs on full power either.
If it's dim then it may not be thermally connected or a dodgy unit.
Posted : 24/09/2009 8:07 pm
My DX P7 out performs my Hope HID
Posted : 24/09/2009 8:10 pm
Thanks joemarshall if it happens again i'll check it out
Posted : 24/09/2009 10:18 pm
