Looking at ordering some tech m4s from merlin. I have 183 disc on the front with post mount forks so I need hope mount H. On the rear I have a 160mm disc so do I need brake mount F or can I just bolt it straight on?
Thanks
Thanks
Assuming it's an IS mount on the back, you'll still need the adapter because your brakes will be post-mount.
Is the rear caliper post mount? If it is you will need mount J. If it is a IS mount rear caliper then it will bolt right on.
I haven't bought them yet so don't know if the rear is IS mount or post. The frame is IS
Forget my second statement Hope tech M4 are post mount calipers, so you will need adapter J.
Thanks.
You must log in to post.
