Talk to me about BB...
[Closed] Talk to me about BB30
[#2687617]
I think I understand that it uses a larger (30mm) spindle etc. But is it frame dependent, or do all bb's fit all frames?
Posted : 24/04/2011 2:01 pm
 rob
yes its frame dependent, BB30 uses press fit bearings rather than threaded bearing cups like ht2/square taper etc
Posted : 24/04/2011 4:29 pm
Ah, so if my current setup uses hollow tech II its NOT bb30?
Posted : 24/04/2011 9:11 pm
Correct, unless it's got adapter cups.
There are a ridiculous number of standards around, and few MTBs are actually bb30. Cannondale are the obvious example! Spesh are very close with their OSBB, but it's not quite the same!
Posted : 24/04/2011 9:55 pm
Hollowtech is IIRC Shimano's term for hollow forging of cranks, rather than BB (HT I was with an Octalink BB if memory serves).
Shimano uses a 24mm spindle with their external BB's; these should also work with most external BBs except SRAM GXP which has a stepped spindle so the DS & NDS bearings are different diameters (I think). BB86/90 is the same width as a conventional threaded external BB but uses press-fit cups so the cranks are compatible.
BB30 uses a larger spindle and moves the bearings back inside the BB so it's narrower than an external BB setup; various adaptors are available to fit 24mm spindle cranks to a BB30 frame but not the other way round. PF30 is the same width but uses similar bearing cups to BB86 rather than bog-standard industrial bearings, the advantage being that PF30 doesn't need a machined metal BB insert unlike BB30 for carbon frames.
There is an increasing number of BB30/PF30 frames about, mainly XC hardtails (the new Jekyll is about the only long-travel BB30 bike I can think of). Confusingly, the Spesh road OSBB is identical to BB30, but the MTB one isn't.
Does that clear things up any? 😛
Andy
Posted : 24/04/2011 10:01 pm
Rotor make a BSA30 BB that allows the use of a BB30 chainset in a standard BB shell.
Vanman
Posted : 24/04/2011 10:13 pm
Google is your friend
Posted : 24/04/2011 10:14 pm
Nice one for all the info. Not sure I'll ever want to take the bb exam, but think I know what I needed to know.
Good to see, as ever, that bike mfg's are making it easy for us.
Posted : 24/04/2011 11:57 pm
