Viewing 4 posts - 1 through 4 (of 4 total)
  • Swapping the cage on a rear derailleur
  • parkedtiger
    Anyone know a technique / trick to replacing the cage on an XTR rear mech ? Preferably without a vice.
    belugabob
    Depends entirely which model you’ve got.
    Check out the tech docs on the Shimano site to help identify where the various bolts are.
    Milky
    Trick? I swapped the chewed carbon bage on my XTR to a medium cage from a Saint. Took the mech off the bike, unbolted the old cage and bolted on the new. Why would you need a vice?
    parkedtiger
    I wasn’t sure if the spring would be an issue. Thanks Milky.
    Thanks belugabob.
The topic ‘Swapping the cage on a rear derailleur’ is closed to new replies.
