sub zero brake blee...
[Closed] sub zero brake bleeding
[#2298060]
apart from getting cold shaky hands, any reason why not?
Can you bleed brakes in cold weather or is it something best left for the warm?
Posted : 19/12/2010 6:58 pm
It's pretty unpleasant... But otherwise fine.
Posted : 19/12/2010 7:10 pm
Magura oil freezes about -15, DOT fluid about -20.
How far sub-zero are you?
And what brake fluid do the Canadians use?
Posted : 19/12/2010 8:16 pm
Dot 4 freezes at -60c, though if it's old and wetted out that can change obviously just like the boiling point. Hydraulic mineral oil varies from product to product, frinstance Citroen LHM fluid has a pour point of -50c but will be thickening before that point.
But you're not likely to be working on the bike in those conditions I reckon.
Posted : 19/12/2010 8:45 pm
After reading the answer from andrewh I had a quick check in the literature that is around here, and the "pour point" for Magura Blood is <50 C.
Just checking... Pay attention at the back there!!
Posted : 22/12/2010 12:32 pm
Dagnabit!! Sorry 'bout the mistake. I Meant <-50°C... Today I'm only seeing the words on the screen 30 seconds after I'm typing them in here...? 😳
Posted : 22/12/2010 1:33 pm
