Stupid Excel questi...
[Closed] Stupid Excel question
[#3047905]
I have three temperatures T1, T2 & T3. How do I write a formula to highlight if one of the temperatures is more than five degrees different to the others. I know I can just look at the three temperatures and see the difference in an instant, but I'm trying to write a formula to make it idiot proof (because I have been known to work with idiots) 🙄
Posted : 14/08/2011 5:26 pm
 mrmo
use an IF statement,
Something like IF t1>t2+5, do x, IF t2>t1+5...
just think of the combinations and should be good to go.
Posted : 14/08/2011 5:30 pm
use "Conditional Formatting" under "Format"
depending on which one you want to be comparing to the other two (or both?) then assume you have columns A, B and C, in Column A set condition format to be:
"Formula is" (from first drop down box)
=OR(A1<(B1-5), A1>(B1+5), A1<(C1-5), A1>(C1+5))
And set a format (that is different to the natural format) in the "format" button.
that particular formula compares A with B and C for +/-5deg simultaneously. You can obviously change the logical test you want the highlighting to be based upon.
Posted : 14/08/2011 5:34 pm
Is the future nuclear safety of the uk really in the hands of STW?
Posted : 14/08/2011 5:36 pm
=IF(AND(MAX($J$7:$J$10)>=MIN($J$7:$J$10)+5,J7=MAX($J$7:$J$10)),"Attention","")
Posted : 14/08/2011 5:59 pm
Thanks again.
Posted : 14/08/2011 8:22 pm
